Results 1 to 10 of 12
Thread: Td5 - R380 how long should they last?
    Oct 2013
    Richmond, NSW
    Hi all
    Just have a concern with longevity of the R380 in my Td5. Back in 2012 when it only had 160k on the clock 5th gear destroyed itself resulting in a reconditioned gearbox and new clutch kit being installed. Now with 260k on the clock it’s in for the same thing!
    I have owned this from new, MY99 and it has never been thrashed or abused. Always well maintained and drive with mechanical sympathy in mind so I thought I could expect a LOT more than 100k out of a gearbox!
    (My 300Tdi had a new gearbox in June and that has 290k and was the original unit.)
    Besides being a very expensive couple of months I am surprised and disappointed that I only got 100k out of it.
    It was rebuilt by a reputable company and installed by the same independent I have been going to for 30 years!
    Anyone had a similar experience?
    Cheers - Simon
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Nov 2014
    Nirvana near Albany W.A.
    They don't like towing heavyish loads in 5th , and if not towing in 5th , should last 3-400 000 if oil is changed on a regular basis .
    What usually happens is the rear bearings aren't up to the job , get excessive play and load up 5th gearset until it destroys itself , replace with heavy duty rear bearings , this will require machining of the rear casing.
    Ashcroft supplies the r380 with this option
    Simon,
    what oil did you have in it and how often changed?
    Oct 2013
    Richmond, NSW
    Thanks discorevy, its never towed on the road, just light loads around the farm so nothing in 5th gear. yes i would be expecting 3-400k too.
    Hi dromader, its running Penrite oils in everything (all of our Defenders do) ATF type F or G and is changed per the Land Rover maintance schedule.
    Travelrover
    Wheelers Hill, Melbourne
    Quote Originally Posted by travelrover View Post
    Your issues seems parallel with Frandsd's that he recently experienced in a round Aus trip that saw us camped in the same places a few times. My Deefer has now done 220k's although the only towing ( that I know of) has been the 1600kg camper for the last 20,000k's.
    Here is his thread
    https://www.aulro.com/afvb/90-110-130-defender-county/269840-td5-defender-r380-gearbox-failure-help.html
    You may need to copy & paste the link. David
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by DeeJay View Post
    Here is his thread
    Thanks David
    Not sure I needed to read that just now as I pick it up tomorrow morning and then have to hit the road at around 3.30 on Monday morning to get to an important meeting in Port Macquarie by 8.30 which is usually 5 hours door to door with no stops.
    cheers - Simon
    Travelrover
    Melrose SA
    I have a friend with a 300tdi Defender with over 600000 kms that tows a car trailer most of the time and his box has never been touched.
    I always find that replacing the rear support bearings and oil pump every 200000 kms keeps them going
    I think the problems partially relate to poorly aligned housings
    Oct 2013
    Richmond, NSW
    Well it made it to Port Macquarie with no gearbox issues. So happy with that.
    I did have another issue which I thought was part of the gearbox issue. The gear lever starts to vibrate loudly over 105kph and gets louder the longer you drive. However if you put downward pressure on the gear lever it will go away for a while. That is still there even though I specifically asked it to be looked at.
    Any ideas what this is and what a solution would be?
    Travelrover
    Nov 2014
    The front prop shaft uni's need to run at 45 degrees from front to rear ( out of phase ) , could also be propshaft out of balance or failing u/j .
    If the vehicle has raised suspension it's better to fit a double cardan front prop shaft and output flange from a discovery 2
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by discorevy View Post
    thanks again discorevy
    its not raised, all standard. I'll look into the prop-shafts though they wouldn't have been touched since the gearbox was last done 100k ago.
    Travelrover
