Results 1 to 10 of 18
Thread: ARB Deluxe bar vs Summit bar - Will they both fit?
    Apr 2016
    New South Wales
    I could be stuck between a rock and a hard place.
    I have a 2011 D4
    ARB tells me they can't fit summit bar to a pre facelift D4 as its not approved for this car, so they are steering me towards the deluxe bar
    However, two issues:
    1) the summit bar looks waaaaay better (in my opinion)
    2) I have the facelift grill and lights which are slightly different therefore I'm worried there would be a strange gap (or worse it wont fit) if I get the deluxe bar.
    Has anyone fitted a deluxe bar to a facelift D4, or has anyone else fitted a summit bar to a pre-facelift d4?
    I want to be sure the mountings are all identical before I buy and spray a new ARB bar.
    Also - how hard are they to fit? ARB said they "probably wont do it" so it's going to be up to me.
    St Helena,Melbourne
    1.13 MB
    Cant help with the bar choice but they are fairly simple to fit but there are some fiddly bits like cutting the inner guard where the bar lower capping meets the plastic liner, indicators need to be wired as well .
    I have attached the fitting instructions that came with my bar which covers D3 to D4 2011.
    ARB Model 3432150i winch bar install instructions.pdf
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2014
    Baldivis WA
    Heres my MY11 D4 with ARB bar. Dont know off the top of my head if its Summit or Deluxe, but i wouldnt have a 4wd without one now. This one came with the car when i bought it 5 years ago.20190806_180740.jpg
    I believe even with the facelift models, the gaps below the lights and grille would remain the same, and mounting points for the bar are also the same, as the facelift D4 still has the same chassis as the pre-facelift vehicles.
    Apr 2016
    New South Wales
    That’s the deluxe, thanks anyway eric
    Dec 2009
    Baldivis WA
    Quote Originally Posted by Eric SDV6SE View Post
    That’s a Deluxe bar, Summit bars have larger diameter tube work and are more rounded on the bar edges.
    This is a Summit bar on my MY14, I have no idea why the photo is sideways
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Apr 2016
    New South Wales
    THnks guys but I really just want info on anyone fitting deluxe to facelift D4 or vice versa
    need to know if the mountings are the same
    Apr 2012
    Whyalla, SA
    Summit bar will fit bit was not approved for earlier models therefore they can’t fit it.
    If you got it yourself and fitted yourself it won’t be a problem.
    Apr 2016
    New South Wales
    That what I suspected tombie, out of curiosity how do you know for sure?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Lukeis View Post
    Yes, local has one fitted. Same brackets etc.
    Dec 2013
    ̶W̶A̶ N̶S̶W̶ SA
    Summit Bar Discovery 4 MY2011
    I think mine is a summit bar. Discovery 4 MY2011
    2017 RR 4.4 SDV8
    2010 D4 3.0 SDV6 Diesel Front Bar, Winch
    2006 D3 4.0 V6 Petrol, Rear Carrier, Snorkel, Long Range Fuel Tank Gone
    1999 D2 4.0 V8 long gone :(
    1990 RRC 3.9 V8 History :(
