                                                10th August 2019, 08:51 PM
			Idle speed seems a bit high??
					Gday all just noticed today that the idle on my 2010 2.7 seems a little higher than normal, I can feel it/hear it  sitting at the lights or in park. Last weekend I serviced the car air filter oil filter and gave the MAF a clean with cleaner, anyone else had this and any tip on what I can do about it.
                                                12th August 2019, 08:02 AM
					Whats your rev counter say?  The EMS should be adjusting air flow and fuelling to achieve the preset idle speed. Have you double checked that the lid of the airbox is properly re seated and that youre not getting false air in somewhere? Not sure on the 2.7,s but my 3.0 idles at 730-735rpm.
                                                12th August 2019, 10:28 AM
					Yeah I should have mentioned the revs, looking at the counter it’s a bit over 800 but I’m sure it was lower than that however yesterday  I gave the maf another squirt and also did the map sensor which was fairly backed up with crud and it is now a little under the 800 but I’m sure it should be around the 750 mark. I’ll recheck the air box is properly seated.
