Results 1 to 9 of 9
Thread: r380 oil guru's question.
    Gear box oil is up for a change and found recommended oil hard to find. In comparing traditional gearbox oil with Syntrans seems the viscosity at various temps seem to be very similar in viscosity. Wondering if I am reading this correctly as considering using penrite outback hardened 80w90 which seems to be very similar in viscosity and not an issue with brass etc. Viscosity may be a little thicker when hot
    80w90
    TYPICAL DATA
    Colour Blue
    Density at 15°C, kg/L 0.894
    Viscosity, Kinematic, cSt at 40°C 152
    Viscosity, Kinematic, cSt at 100°C 15
    Viscosity Index 99
    Viscosity, Brookfield at -26°C 53,800
    Phosphorus, Mass % 0.06
    Syntrans
    Viscosity, Kinematic100°C ASTM D445 mm²/s 11.9
    Viscosity, Kinematic 40°C ASTM D445 mm²/s 64.4
    Viscosity, Brookfield @ - 40°C (75W)
    DIN 51398 mPa.s (cP) 18000
    Pour Point DIN-ISO 3016 °C -45
    Density DIN EN ISO
    12185
    g/ml 0.837
    Have I missed something??
    NSW far north coast
    Totally different viscosities when cold!
    Look at the viscosity and VII. r380 oil guru's question.
    152 vs 64@40°!
    I'm in the phone atm but if we plugged those numbers into a viscosity calculator the 80w-90 would be like treacle at close to zero, and probably bugger the 'box as it possibly wouldn't flow through the galleries fast enough to lube the bearings
    That 80w-90 would be bloody awful, don't skimp on using a decent fluid in that 'box.
    Plenty of posts and threads on here on what is used and what works well.
    I have just changed the oil in my R380. I run Penrite in everything else in my Defender, apart from the R380 which I have always used Castrol Syntrans 75W-85 full synthetic.
    The R380 was due for a change so I decided to try the Penrite Progear 75W-85.
    Now I am unable to select second when the box is cold. So this weekend I will be swapping back to Castrol Syntrans 75W-85. It's not cheap - at about $33 for 1 litre at Repco. But it's worth it in my opinion, My box shifts super smooth at all temperatures using the Castrol Syn Trans.
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Quote Originally Posted by 86mud View Post
    Thanks, exactly what I was after
    When I had my D1 I had Syn trans in it.
    Ok on -5 Canberra winter mornings and also Ok on +40 Canberra Summer afternoons.
    Just go with SynTrans - never saw it as high as $33 a litre but then I buy oils when on special.
    Aug 2015
    Moe
    X2
    Mark F...
    Vk3KW
    2002 D2 Td5 auto - current AKA The Citrus Money Pit
    2000 Disco 2 Td5 Manual - dead and gone
    197? Range Rover - gone
    1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
    Outback Campers Sturt
    http://jandmf.com
    in the wild New England, NSW
    I know that Syntrans is expen$ive - but much, much longer oil change intervals are recommended.
    Melrose SA
    The only problem with Syntrans is it shears quite badly within 20000 kms
    Requiring a change interval of no more than 20000
    On the advice of Rick I used motul 300 an absolute bitch to change when it’s cold but magic once it warms up
    NSW far north coast
    Quote Originally Posted by djam1 View Post
    Duane, that just goes to show how idiosyncratic the R380 is as I found Gear 300 better when cold than Syntrans!
    Unless Motul have reformulated in the last four years, which could've happened?
    It definitely survives longer than Syntrans, with a much better change in high ambient/high load conditions
