Results 1 to 6 of 6
Thread: Disc Caliper Metal Retaining Rings
    Outer Sydney
    Good evening all,
    I recently put new seals through the RHS disc caliper (AP Lockheed) on my '84 110. The job was straightforward until I had to put the new seal retaining rings in - they were certainly a test of my patience! I found that i had to reuse two of the old ones (still in good nick) as they were a smidgen narrower than the new ones.
    I'm wondering if it is even necessary to replace the retaining rings? Can i simply leave them in place and slip the new seals in behind, then push the greased caliper piston in?
    Thank you,
    Edward
    The metal ring holds the outer rubber dust seal.
    I found that you need to make sure that the groove in the caliper is super clean so focus on this before trying to fit the metal ring. Use a blade of a small screwdriver to carefully clean out the groove.
    The metal ring needs to be pushed in with your fingers first, then gently tapped in. I often use the handle of a shifting spanner.
    I never split the caliper when changing seals
    Good luck
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Outer Sydney
    Thanks Andrew. You make it sound so easy, but for some reason mine were anything but! I wonder if my new rings were very slightly oversize? I believe they were a good brand (it said genuine OE on the box, made in the UK by Liberty). Like i said, i had to reuse two of the old ones, which pushed in a lot better.
    Edward
    Outer Sydney
    This is the brand of my kit (image from Google).
    Adelaide - Torrens Park
    I have come across those rings falling out of rebuilt calipers, twice in a row, two different rebuilders. My advice would be to leave them in place and slip the seals past them.
    I had problems with this when I did up my callipers years ago. Needed to re-use some of the older retainers.
    There are threads on this site with info if you have a look such as this one:
    servicing Brake Calipers , "How to"
    DL
