The S2 diesel would have been a 2.0. By the time it was due for overhaul, parts would have been difficult, as that engine was replaced by the 2.25 diesel. This may explain the change, and fitting a petrol would have been a lot cheaper and easier than fitting a 2.25 diesel.
In my view the overdrive is not very useful on a lwb - I have fitted one, but almost never use it. It is coming off when I get round to it.
Note that the petrol and diesel (and six cylinder, but not the bell housing) gearboxes are identical, but there were a number of changes over the years, with the later the 2a box the tougher, in particular, the transfer case after about chassis suffix 'B' had a larger diameter intermediate shaft. Also gear ratios changed, but high range remained the same and the combination of first-low remained the same, but the main box ratios varied with the transfer low range changing to keep the overall lowest gear the same.
