Results 1 to 10 of 11
Thread: Water sand blasting galvanised and aluminium
    Feb 2018
    East Gippsland
    I am just starting to think about how I am going to prep the panels on an S2a for painting. I prefer the patina look but for me it isn’t an option as I have a couple of panels of different colours as well as paint over the gal trim.
    Knowing how aggressive sandblasting is as well as the aluminium warping issues I have started to think about water sandblasting, with domestic equipment.
    I see K’archer do a sand/ wet blasting kit
    Sand/wet blasting set | Karcher Australia
    Looks cheap enough and the u Tube videos make the process look effective enough. Hopefully I can be gentle enough to remove only the paint off the steel capping a and leave the gal, but properly clean the aluminium. Certainly there won’t be any heat.
    Does anyone have any experience with anything like this- or do I need to go back to paint stripper?
    Richard
    Dec 2008
    Tewantin, Qld
    Hi Richard,
    I’ve had one of these for a few years. It works well, I use beach sand and recycle it, but you have to dry it and sieve it down to 1mm. The sand needs to be super dry and needs to remain above the spray head, otherwise water runs back down the pickup tube and blocks everything up.
    Its pretty gentle compared to some of the dry sand blasting I’ve seen and I recon you could take the paint off without too much gal. Don’t know about the panels as the water might do more damage then the sand in terms of weight. I find that my finish is a lot finer the second time the sand goes around.
    It goes thru the sand pretty quickly, the only time I measured, it took about 30l of sand to do a 14 inch rim inside and out.
    Cheers Glen
    Sep 2012
    Westlake ,brisbane
    Soda blasting I believe is not as aggressive on the alum.
    You can 'sandblast' with stuff other than sand, either wet or dry. Soda blasting is suitable for both alloy and galv. Another alternative is nut shells, which is even gentler.
    Beach sand should never be used for dry sandblasting as it carries a high risk of silicosis - which is something you really do not want to get, and neither do your neighbours. Sand itself is harmless - if you breath it in it gets trapped in your nose or throat. But when it is blasted at high speed against hard surfaces, or against another grain, bits of silica of all sizes are broken off.
    Fine dust size silica makes its way into the lungs and becomes trapped causing permanent scar tissue, which destroys the function of the lungs. Silica is worse than any other common dust, with others either dissolving in the blood stream or at least not causing as much scarring. Coal dust is bad (black lung), but nowhere near as bad as silica. Perhaps it is not as bad as asbestos, because it will not cause cancer, but if you can't breath you are dead anyway.
    Historically it has been a disease of miners and quarrymen, but in recent years the use of power tools to grind and cut concrete (made with silica sand) has made a new epidemic. Professional sandblasters know about this, and don't use beach sand.
    Sep 2012
    Westlake ,brisbane
    Ihe guy I use uses glass.
    Safe enough, but probably a bit harsh for either alloy or galv.
    Apr 2015
    Hervey Bay
    Have you thought about removing the paint with paint stripper? I stripped all the panels on my RRC a few years back with the "CAM" brand stripper you can get from a auto paint shop. It was quick and easy and quite cheap. A 4L tin was about 45 bucks and I ended up using a tin and a half to strip the whole car.
    I started using the Septone stripper from Bunnings but that stuff is more expensive and junk compared to CAM. I found a nice thick coat of CAM and left for half an hour, scrap off the majority of it and water blast what's left works a treat.
    But be careful and don't do what I did. I forgot my Jag was to close to where I was working on the other side of the fence and a chunk of stripper landed on the bonnet . It wasn't that big a deal as I'd only painted the Jag a couple of months earlier and had the necessary paint to repaint the bonnet, but I would have preferred not to make the extra work for myself.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Sep 2012
    Westlake ,brisbane
    Depends on who is operating the blasting equipment. this guy sand blasted all my 80" panels going back 30 years ago & did not buckle any of the panels . He used to do a lot of blasting for my brother & I before we retired & sold our steel & alum fabrication business, & he did a lot of alum blasting for us . He has started using glass about 20 years ago as it was better for his health . He is a one man show.
    Feb 2018
    East Gippsland
    Thanks for all the info Guys - there are plenty of options, my main driver is to clean without removing the steel galv capping. I really don’t want to or need to re- rivet! The more I can leave it original the better.
    I think when I start I will pressure wash and start with paint stripper and see where I end up.
    Again thanks.
    St Helena,Melbourne
    4.28 MB
    A blaster i used years ago was using crushed apricot kernels, gentle on panels but not as efficient as more abrasive media.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
