Thread: Double DIN or Single with Fold Out Screen
    Jul 2014
    Hobart, Tas
    Hi all,
    I'm looking to get a reversing camera and new head unit but cant get my head around the options and alternatives for a double v single DIN unit. I understand if I go with a double DIN then I need to do a lot more dash work whereas a single din with fold out screen should slot straight in so is a bit more appealing. See below;
    Best Flip Out Head Unit & Stereos - 5 Products To Consider For 2019
    A fold out unit will block a few dash buttons but I could relocate the rear wiper to an outer location and I shouldn't need the hazards anyway (I hope)
    Anyone had any experience with the fold outs or is a double DIN worth the faff?
    Apr 2015
    Hervey Bay
    I put a flip out Pioneer unit in my RRC soft dash a while back and I liked it.
    You don't have to worry about relocating the buttons behind the screen as you can press a button on the unit and fold the screen back in while it is still in use. You can still control the unit with the screen in with the use of the buttons and dial on the front.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    DiscoMick Guest
    We put in a Polaris double DIN unit sitting on top of the dash, fully installed with forward and reverse cameras and Hema maps. Very happy with it. Cost about half as much as pulling the dash apart would have, plus if we ever sell we can take it with us.
    Jul 2014
    Hobart, Tas
    Quote Originally Posted by DiscoMick View Post
    Sounds interesting. Any chance of a pic?
    Andrew
    St Helena,Melbourne
    4.28 MB
    What about one of these, single din fixed screen.
    https://www.joyingauto.com/single-din-car-radio.html
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    DiscoMick Guest
    Quote Originally Posted by 4xsama View Post
    Andrew
    Buy GPS | Rear Vision Camera | Dash Cam & More - My Polaris
    Jul 2014
    Hobart, Tas
    For anyone who has done a swap from the stock Alpine head unit to another brand are the plugs the same? Also, does the stock amp work on a different head unit (assuming similar specs).
    In a change over I'd want to be able to pull one out and put a new one in with minimal faff.
    Jul 2019
    I haven't done the upgrade yet, but it's on my list of things to do.
    My plan is to use this double din kit:
    Aerpro | First Choice
    And this head unit with reverse camera:
    iLX-702D-CAM Alpine Electronics of Australia
    Alpine to Alpine switcheroo should be the same plugs, but if not, Aerpro sells a million different types of loom adaptors.
    Looking forward to having CarPlay again.
    I'd love to hear if anyone else has used that Aerpro kit, because I've had a search but can't anyone mentioning it?
    St Helena,Melbourne
    4.28 MB
    Most LR's from late D1 up use iso plugs so some brands will plug right in or require an adapter loom which is only about $15-20 from Aerpro.
    1974 VW Kombi bus
    DiscoMick Guest
    Thanks. I've been offered an Alpine head unit and a sub with amp from a D2 and I'm hoping the head will plug straight in to our Defender, which has an el cheapo head unit replacing the original.
