Australian production White trucks had these over 40 years ago.
Hi All,
Anyone done this mod? If so, how does it perform?
Windscreen washer jet improvement.... - Defender Forum - LR4x4 - The Land Rover Forum
Andrew
URSUSMAJOR
Hi Andrew
I tried ordering that one from megasquirt last year and got no response from numerous requests. They seem to be closed to attend various shows a lot of the time. I ended up buying something similar and cheaper locally, search this on eBay “Windscreen Washer Jets Universal Conversion Kit ( bonnet/scuttle to Wiper Arms)”
It works well and even if you carry the spare on the bonnet which can sometimes disrupt the airflow and washers.
Cheers - Simon
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
I seem to remember Britpart offering them, but I could be wrong.
Rather than buy the kit of parts you can get the nozzles direct from China.
1Pc Plastic Universal Black Car Blade Arm Washer Wiper Water Spray Jet Nozzle ~ | eBay
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
BUMP
I saw them listed in the optional equipment catalogue for a 2a in the mid sixties!
You can use the flexible tube and fittings sold at Bunnings for garden dripper systems to plumb the system. Cheap and as they are designed to be used outdoors the UV doesn't worry them either.
I made my own version that looks similar to that setup, but I used 4mm brass tube from a modelling supplies shop for the spray rails, and uv stabilised black irrigation tubing. It goes very well, but I've been thinking of putting more holes in the rails. I might have to supercharge the little pump if I go overboard with the holes though.
Don.
