Sorry mate, no. You won’t be able to make that fit
Would anyone know if I can fit my Thomas 8000lb winch on my 2013 D4? The pic is of a very similar one. The only difference is that mine is the same electric but has a backup crank handle.
My D4 is currently stock, so no bullbar, hidden winch cradle, etc.
"Land Rover - making mechanics out of everyday motorists for nearly 70 years"
Wouldn't a 8000lb winch be a bit undergunned for a heavy 4WD like D4?, 12000lb or more would be a better match.
4.6m Quintrex boat
Bummer. Looks like the Thomas is going on the market. Sad face.
I haven’t heard about Runva before, but ip67 rating, descent guarantee, local agents, plus not planning on needing the winch more than a couple of times in its life means Runva might be the way to go.
4X4 Electric Series
With Any make of electric winch if you don't use it you will loose it.
All you have to do is to run out 15-20m of rope and wind it back on every month or so, If you don't do this then there is a very real chance that when you actually need the winch it will fail and it only takes a couple of min to do.
4.6m Quintrex boat
Also look at the kings domin8tor and grande 12k winches, under $400 and work well.
Put a grande on mine.![]()
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
