Results 1 to 4 of 4
Thread: SRS Light Discovery 1 - TRW MPS
    May 2018
    Geelong
    Hi, hopefully someone can help out,
    Need to read a code from a 96 Discovery 1 with the SRS light on.
    From what I have researched that will be either a "Logic 4" or a "Hawkeye Total"
    I don't suppose anyone around Geelong / West Melbourne has one I could borrow / rent?
    Looked at the list and map but it seems that everyone has a Nanocom, which I don't think will do the trick...
    Dec 2012
    Stuart Town
    If you can't find a fault reader, look up the blink test.
    Discovery I - ABS Blink Code Procedure
    1996 Disco 1 300TDI manual - Lucille a cantankerous red head! :D
    1997 Disco 1 300TDI Auto - sold
    Jul 2007
    jan juc
    I don't think a Nanocom, will work on it as tdi is not obd 2 compliant. I used the blink test (used a paper clip I think to bridge the terminals )when I had my tdi found it was the brake light switch that was the cause of the problem.
    Sep 2010
    The Hills.
    152.79 MB
    Nanocom is useless here. I believe Dave ( Blknight.aus ) is over your way, and he is pretty sharp. Maybe PM him.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
