Results 1 to 6 of 6
Thread: BUSHMASTER Water tank
    Brisbane, Australia
    Good evening
    Does anyone on the forum know how many litres of water an Australian Army Bushmaster holds?
    Thanks.
    99.87 MB
    It depends on the model.
    2006 is 211 litres.
    https://web.archive.org/web/20060823...eng_170206.pdf
    2012 is 250 litres. Apparently it sits under the hull as an explosives buffer.
    http://www.warwheels.net/images/Bush...esBrochure.pdf
    Slunnie
    ~180l is immediately usable, you need to park up on an angle to get the in tank pump to get the rest and you still wind up needing to manually pull out the last bit with a syphon hose as part of the 12 monthly clean up.
    Brisbane, Australia
    Bushmaster Water tank
    Quote Originally Posted by poundsterling View Post
    Good evening
    Thanks.
    Thanks to Slunnie and Blknight for your prompt replies,
    Cheers.
    Brisbane, Australia
    BUSHMASTER water tanks
    Cheers.
    Attached a couple of photos for the record. Final question does the shape indicate the capacity?
    Cheers.
    generally yes but its an odd shape so its hard to guestimate
