Results 1 to 9 of 9
Thread: Vacuum offtake
    Jul 2012
    Vacuum offtake
    Hello from Sherwood.
    Making a bit of progress on getting my truck back together. Another question to keep that process moving forward.
    I’m fitting boosted brakes to a Series 3 truck that never had them originally. So, there is no offtake point on the present inlet manifold for the vacuum hose - the engine is from an earlier 2A model that also didn’t have boosted brakes.
    Does it matter where the manifold is actually tapped for the offtake nipple and hose? I have seen a manifold on a Game that had the offtake hose fitting centred behind the manifold below the carburettor. The parts manual shows a pipe that appears to be fitted on top of the manifold towards the end near the firewall.
    Neil
    1975 S3 88" - Ratel
    Jul 2012
    Hello again from Brisbane.
    Just wondering if there was any thoughts on the best location for the vacuum hose offtake on a manifold that doesn’t already have one.
    Neil
    1975 S3 88" - Ratel
    From memory there is a flat cast on the top of the manifold for the purpose, behind the carburettor. But the actual location is not critical.
    Jul 2012
    John,
    Thanks.
    Neil
    1975 S3 88" - Ratel
    its not critical BUT...
    IMHO..
    its best to draw it off directly under the carby from a bolt in plate.
    you might also want to consider an electric vac pump.
    Jul 2012
    IMHO..
    Hello and thanks.
    I’m not the most gifted mechanic - but I try. Could you expand on how that is actually best configured?
    Neil
    1975 S3 88" - Ratel
    grab a 10mm plate of ally, cut out the holes for the carby, side drill it and fit an 8mm barb.
    think adaptor plate and you're on the right track
    wrong engine and carb but same idea
    Jul 2012
    Dave,
    Hello again and thanks.
    That’s what I thought you might have been suggesting.
    Neil
    1975 S3 88" - Ratel
