Results 1 to 10 of 39
Thread: Portal front end
    Apr 2002
    Bellara 4507
    32.43 MB
    Thumbs up
    Your thoughts on the portal front end.
    if you voted no or other please let me know your thoughts...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    HSVRangie Guest
    <div class='quotetop'>QUOTE(incisor &#064; May 16 2006, 11&#58;41 AM) Quoted post</div><div class='quotemain'>
    [/b][/quote]
    Go portals all araound.
    Michael.
    I think I had to login once for the portal and once for the forum.
    Simon
    Apr 2002
    Bellara 4507
    32.43 MB
    <div class='quotetop'>QUOTE(abaddonxi &#064; May 16 2006, 12&#58;15 PM) Quoted post</div><div class='quotemain'> I think I had to login once for the portal and once for the forum.
    Simon [/b][/quote]
    you should only need to login to the portal first and it should talk to the forums ...
    It&#39;s good. However I think I&#39;d like o see the forums open in another window rather than sit within the portal so thot you get a bit more real estate
     2005 Defender 110 
    Feb 2005
    [/b][/quote]
    i&#39;m guessing we are talking the site and not diffs and axles, can somebody explain portals to me
    <div class='quotetop'>QUOTE(weeds &#064; May 16 2006, 12&#58;49 PM) Quoted post</div><div class='quotemain'>
    [/b][/quote]
    They are what you lean through to pull up the anchor in your half cabin dingy mate
    Ferntree Gully VIC
    <div class='quotetop'>QUOTE(Captain_Rightfoot &#064; May 16 2006, 02&#58;41 PM) Quoted post</div><div class='quotemain'>
    [/b][/quote]
    same here captain.............
    130's rule
    Apr 2002
    Bellara 4507
    32.43 MB
    <div class='quotetop'>QUOTE(Captain_Rightfoot &#064; May 16 2006, 12&#58;41 PM) Quoted post</div><div class='quotemain'> It&#39;s good. However I think I&#39;d like o see the forums open in another window rather than sit within the portal so thot you get a bit more real estate [/b][/quote]
    thats what will happen eventually... for the moment i need it with the primary browser window...
    Bracken Ridge, Qld
    Simon
    [/b][/quote]
    Yeah the same happened to me.
    I put it down to teething problems.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
