Nice start, but unless you bolt down the passenger side of that fridge slide going around a LH corner will cause the fridge to lean and possibly break the bolted runners. I would have extended the wood right the way across and the bolt it to the LHS tie down points. I carry a fridge in my car when we do short trips or I want a extra beer fridge. I cut some thick metal strips to go right the way across to each tie down point and welded two links of a chain x4 to the strip metal on each side just a bit wider than the fridge. A rachet strap hooked on one side through the fridge handle and hooked on the other side holds the fridge in place. That way I still can slide things in the other half of the cargo area. I had a wooden storage system in my last car and they are very heavy! So watch your weights! Good Luck
2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
