Results 1 to 4 of 4
Thread: Where to get Rangie parts?
    Steeny Guest
    Hi guys, it's Julz again,
    Can someone tell where the best place on the internet is to buy Range Rover parts and also is it possible just to buy the brake senor/sender part or will I have to buy the complete brake master cylinder.
    The Rangie is a 1986 model.
    Julz
    Avoca Beach
    What is a brake "senor/sender part"
    Philip A
    St Helena,Melbourne
    4.28 MB
    <div class='quotetop'>QUOTE(Steeny &#064; May 16 2006, 05&#58;58 PM) Quoted post</div><div class='quotemain'>
    Hi guys, it&#39;s Julz again,
    Julz
    [/b][/quote]
    Julz, i recently had my m/cylinder re- sleeved for &#036;70, did a great job and its now good as new - new price cheapest price i found was about &#036;285 &#33; the sensor i guess you mean the brake circuit warning sensor that plugs in the side of the cylinder in between the 2 outlet pipes ? mine broke off so i just fitted a bolt in its place.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Steeny Guest
    Hi,
    Thanks Loanrangie
    We put a bolt in place of the senor today and went bush, no problems or leaks. Aren&#39;t these Rangies just great.
    Hi Phillip A, the brake senor/sender is what Loanrangie said it is, the brake circuit warning senor, it tells you when you have low or leaking break fluid.
    Thanks agin I know you guys have always got good ideas.
    Julz
