Results 1 to 3 of 3
Thread: V8 LT85 vs 4bd1 LT85?
    Jul 2011
    Canada
    Is there any difference between a V8 LT85 and a 4bd1 LT85 other than the bellhousing? Are the first motion/input shafts the same? Thanks.
    Update: I've been told they are the same other than the bellhousing.
    Melrose SA
    Quote Originally Posted by headdamage View Post
    There are 2 LT85 cases a split and a solid case, the solid case is much stronger than the split case. I know it doesnt answer your question but it may assist you in your quest.
    Hay Point
    Yes, exactly the same box except for the bellhousing.
    Cheers......Brian
    1985 110 V8 County
