Thread: Rebuild 4bd1 fuel feed/lift pump?
    Jun 2016
    United States
    I've had to replace this on one of the rovers twoce in 20 months. Was wondering if anyone has rebuilt them and if so, whether there are recommendations regarding a kit or parts, procedure, etc?
    The issue started, I believe, because the old tank was flaking debris so this time I removed the tank and cleaned/sealed/replaced, then replaced the fuel feed line to be sure the diesel stays tidy. A few times I had lost power and been able to cleanout the banjo to get going again, but it was time to try and solve the problem.
    Just in case, I'd like to rebuild the lift pump so it's on the shelf, ready, if ever needed again.
    Scratching my teenage itch now that I'm in my midlife crisis...
    '87 110 County 4BD1+T+LP (Godzilla)
    '88 110 Perentie Cargo 4BD1+T+LP (Thing1)
    '91 110 Perentie Cargo 4BD1+T+LP (Thing2)
    Hay Point
    Must admit I have never had to rebuild one, but I would imagine it wouldn't be hard to do. I always carry a spare one on long isolated trips just in case. One thing I thinks help extend the life of the lift pump is to add a fuel filter in the line before the pump which catches all that crap that blocks the small lint filter in the banjo bolt.
    Cheers......Brian
    1985 110 V8 County
    Brisbane, Queensland
    Quote Originally Posted by Bearman View Post
    I also fitted a plastic inline petrol filter, just to stop the lift pump screen getting blocked. It also allows you to see if there’s fuel in the line if there is a starting problem.
    One thing you should also do is clean out the water separator. It does a good job at collecting bigger particles.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Geelong, VIC
    I've fitted a CAV fuel filter in place of the sedimenter. Filters are cheap and a decent size so won't block easily.
    Quick and easy to change too if you happen to pick up some dirty fuel.
    I haven't had to change or rebuild a lift pump, but can't imagine there would be any rocket science involved.
    Its been a about 5 years since I did my water pump rebuild but at that time genuine rebuild parts for the water pump were still easily available. Hopefully the same case for the lift pump.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Quote Originally Posted by steveG View Post
    Steve
    I initially did the same. Then I refitted the water separator as it does a great job as a pre-filter, picking up sludge and sand size particles like rust. I will probably refit my Racor filter one day.
    REMLR # 137
    Oct 2012
    FNQ
    Bosch. 2 447 010 038. on Amazon
    AM
    Davehoos Guest
    Inline petrol style fuel filter are common fitted and ive often had issues with these resticting the fuel supply with small diesel engines.
    Ive been fitting a stainless strainer from Case backhoe/cummings engine
    as pre filters for lift pump. these are easy to back flush.
    has 5/16 olive conection at one end, that fits to the fuel pump , and barb 3/8 at the other. I have seen similar with 5/16 olive fitting fitted to rover V8 after the mechanical pump but are NLA and its recomended a paper filter..
    Same thing with 3/8 fittings each end are common as tank breather with heavy machinery if you have hoses that size.
    I was getting a john deer mech [steel wool] strainer from a 5000 series tractor to protect a bosch rotary primer pump. these had quick snap on conections 5/16 my understanding these are genuine only. I cut plenty open and never had seen one contaminated. but it stops gravel.
    I did a google looing for the other part numbers and found this baldwin part to suit 5/16 rubber hose conversion for that filter.
    BF9916
