Results 1 to 2 of 2
Thread: Ignition Coil
    Dec 2010
    Kiewa Valley, VIC
    Ignition Coil
    Will a c80 be a suitable direct replacement for my very old and original Lucas coil?
    1956 swb 2.0
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    JDNSW's Avatar
    I don't know the C80, but it will work if it is 12v and designed to be used without a ballast resistor.
    Ideally, it would be designed for positive earth (assuming you still have that), but in practice this makes no detectable difference.
    Any modern coil almost certainly has a snap in HT connector, so you will have to change the end on the HT lead, but this not an issue unless you are a rivet counter.
