Are you 100% sure it is the compressor though? It could be one of many things & that may alter a claim?
Murphy’s Law, just out of warranty and my aircon has decided I don’t need to keep cool this summer. Am I right or wrong to hope that under consumer law, I should be able to assume that the aircon compressor ought to last longer than 3 years and 66,000km...and LR should fix this at no cost to me?
Consumer Affairs in your state will give you free advice on your rights and the best approach to resolve. They can also get involved then if this does not work.
If the issue is you need a new compressor then you may be covered, but if it is a regas or a minor fault then this may be considered wear and tear.
Typically Consumer Affairs will suggest you contact the dealer and try to resolve first before then getting them involved.
It is common the valve on the compressor fails. Mine is dud and so it takes ages to start cooling some days. I’d agree it’s a reasonable argument that it should last longer if that is in fact the issue
2007 Audi RS4 (B7)
Just checked it again in the driveway. I can hear the compressor clicking on okay, cool air is fine on the passenger side of the car. But ambient temp on the driver’s side, both right front and right second row aren’t blowing cold at all. What th...?
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
Cheers, Dale
'The D3' - 2006 TDV6 HSE
Previously Enjoyed:
2000 D2 Td5 - plus!
