Thread: EV Ninety conversion
    Jul 2011
    Yarrawonga, Vic
    Pictures from the "EV Landy & 4x4 conversion" Facebook Group by Retter in Hungary.
    no details, the DEFENDER name is clever . Thats one huge motor !!
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    What size motor is that? That thing will fly!
    Aug 2008
    Perth, WA
    37.36 MB
    Wow, that motor is huge. I expect this to be one of the few Defenders with the ability to smoke up all four wheels. Would love to see the specs.
    Life is just a series of obstacles preventing you from taking a nap.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by cripesamighty View Post
    You mean snap all 4 axles EV Ninety conversion
    VladTepes's Avatar
    Bracken Ridge, Qld
    Well, that's awesome.
    As many battery packs as it may have, with that mtor they won't last all that long I'll bet Not a real issue in Germany as never far from somewhere to charge up.
    Here in Aussie-land, not so much.
    Would I own one if I could, here in Aus?
    Hell, yes !
    Can picture tootling around the glasshouse mtns in that
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    May 2009
    West Gippsland - Victoria
    Does it really need a gearbox and TC with that big engine ? Engine/dynamic/regenerative braking should be pretty good.
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    NSW far north coast
    The CSIRO developed a really trick, high speed and very efficient brushless DC motor about 10-15 years ago.
    It's used in large chiller systems (AC systems that chill water as a secondary refrigerant)
    Unfortunately the tech was sold off shore, along with the electro magnetic bearing (oil-less) 2 stage centrifugal compressor it drives.
    Motor speeds up to 30,000RPM IIRC EV Ninety conversion
    What sort or rev range do the Tesla motors operate in?
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by DeanoH View Post
    Deano
    You need 6000 NM at the wheel to climb a vertical obstacle , I only have a 150 Nm motor but have 6500 in Low 1st
    Lets say that monster motor is 600Nm x diff 3.54 = 2124 not enough , x Low range transfer case 3.32 = 7051 , yep dont need the gearbox but does need the TC .
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by rick130 View Post
    Tesla motors max at 18,000 RPM , the Model S has a 9.73:1 reduction . Max torque from zero RPM
    as an asides The HPEVS AC51 motor in my Landy is good to 10,000RPM but the flywheel is not, I tried it up to 7500RPM (scary) but now have it limited in software to 6000RPM. Its happy at 100kph in top gear - 4070RPM . 3rd gear at 100kph is 6000 RPM and you really do want to reach for the gearstick for no reason other than to quieten the gear noise.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Deano
    Not really I don’t think but you’d have to find or build something to split the drivetrain front and rear, so using the existing box and TC simplifies the installation I should think. GB should be able to answer that with certainty as he’s kept the box and TC in his.
