Behind glovebox
Can anyone tell me where the fuse is located for the power outlet in the luggage compartment?
Behind glovebox
Thanks!
OK, the power outlet is dead.
Fuse #55 is not the problem! According to the book it covers the centre and rear power outlets. The centre outlet is working but the rear isn't.
Any suggestions? I suspect its a job for the dealer!
Was it working before? If not it's possibly unplugged
2009 Range Rover Sport 3.6L TDV8
2017 Jaguar XE R-Sport
Supercharged Jags XKR & XJR 4.2L S/C
Old Jaguar Australia - www.facebook.com/oldjaguarau
Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
It probably has still. I’d suggest that is not the fuse you’re looking for. Time to get a meter out and test alternatives.
2007 Audi RS4 (B7)
Hi Barraman, this might save you some time.
Leave all the fuses in place. Use your multi meter probes, place the negative probe on a good earth then just touch the two small silver tabs on the top of each fuse with the positive probe.
If the fuse is not powered, you will get no readings off either tab.
If the fuse powered and is good, you will get a voltage reading on both tabs.
If the fuse is blown, only one tab will give a positive reading.
OK thanks - I’ll try that.
