Page 1 of 8 123 ... LastLast
Results 1 to 10 of 71
Thread: Defender second battery location
    May 2016
    NSW
    Have a tdi300.
    Car isn't with me so can't measure it up but from memory I'd fit a second N70 under the passenger seat.
    Just not sure if a ctek dc to dc would fit under there as well. Does anyone have two n70 under passenger seat and a dc to dc as well? Or would there be room?
    Other option is under drivers seat, guessing an N70 or even bigger would fit fine.
    Jan 2010
    Will it fit. Yes!
    Are you about to get chastised for opting for a DCDC charger set up - probably!
    I have a ctek , two batteries n70ish, a cut off switch, an alarm unit, fuse box, and custom electical box for voltage sensitive switching. All tucked in there
    If you go for DCDC, its not a bad idea to have all your load switched to the alternator when driving. That way all the DCDC amps are dedicated to charging your aux.
    Or keep it simple, avoid the ctek and just have a voltage sensitive relay.
    I went with ctek for solar and to limit load on the alternator when starting up on a depleted aux.
    Que drivesafe
    Oct 2012
    FNQ
    2- 130 ah and even a roll of shock absorber bushes
    Apr 2012
    Whyalla, SA
    I’ll do it Manic...
    A DcDc charger is a woftam in these vehicles. Defender second battery location
    Put the money into an SC90 or equivalent and use the rest for beer tickets.
    There, all done.
    Jan 2010
    May the OP has a good reason for dcdc. Lithium perhaps?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by manic View Post
    Certainly wouldn’t be fitting a Ctek to control a Lithium Defender second battery location
    A good single Lifepo4 will have it’s own BMS now.
    May 2016
    NSW
    Its for an AGM, also want the ability to add solar.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Rexy View Post
    Simple system and a Victron Solar Charge controller.
    Ctek will cripple your charging system reducing charge capability and increasing time to recharge.
    DiscoMick Guest
    I had this dilemma, but went a different route, because of the limited space in the battery box.
    I had Off Road Systems (ORS) build drawers for the rear, but got a short drawer. That left space behind the drawer for a battery on its side. There is a lift off lid, or the rear seats can be folded for access. Wiring and a DBC connect the first and second batteries. A solar panel on the roof rack is permanently connected through a simple PWM regulator next to the starting battery. Anderson plugs connected to both batteries allow extra solar or a generator with portable 25 amp charger to be connected to either battery just by opening a vehicle door. No need for a DC-DC charger in the vehicle.
    Having it all hidden works well. We are on the road for three months and it's all good.
    I'm very happy with this setup.
    BTW lithium need special chargers which can charge at 14.7 volts.
    Apr 2012
    Whyalla, SA
    Would work well Mick. Defender second battery location
    My reason for staying with the under seat boxes is central and low mass. ‘Lara’ was quite heavy bias to the rear axle and really didn’t want to add more back there if avoidable.
