Thread: Range Rover L322 Electrical Fault
    AnthonyC Guest
    Hi,I have a 2003 range rover L322 . I have an electrical problem when my wipers fail, my electric rear windows fail, boot opening fails .I have replaced the ECU under drivers seat.I have replaced car battery. The problem keeps reoccurring.Does anyone have a solution for my vehicle?
    Mar 2007
    Anthony did you check the wiper relay ? The BCU will cut power to your wipers if the blades become stuck, a relay fault might be tripping the BCU ?
    Laurie
    Have you had the car scanned for faults?
    AnthonyC Guest
    Quote Originally Posted by Laurie View Post
    Laurie
    Thankyou Laurie, I will check with the mechanic
    Jun 2019
    South West Rocks
    Anthony - I had a similar problem with my 2003 L322 after I replaced the battery. Turns out the bcm had defaulted back to delivery or transport mode which (for some unknown reason) prevents the rear wiper and tailgate from working, as well as the front interior light and a couple of other things I don’t recall.
    It was an easy fix with the GAP diagnostic tool if you have one? I’m sure your local dealer could also do it (for a price), but don’t let them tell you you need a new bcm.
    Might be worth looking into.
    Quote Originally Posted by OllyP View Post
    See my post: Explanation of the reasons for the keyfob re-sync steps
    Mar 2007
    Might be a long shot but, the wiring harness sometimes moves and gets squashed by the rear seat frame on the RHS near the shock mount. This has caused multiple types of problems and error codes in the past !
    Laurie
