Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: M62 TU timing chains and Vanos rebuild
    Jan 2011
    Hi All.
    I’m in the middle of replacing the timing chains, guides and rebuilding the Vanos. The upper u shaped guide decided to part with its plastic.... M62 TU timing chains and Vanos rebuild
    Just got the lower cover off and there’s a lot of black gunk in there. Is this normal for a 265000 km engine? Or was it poorly serviced before I bought it I wonder?
    Apr 2015
    Hervey Bay
    Maybe it's normal with an engine with that many miles on it. I've worked out that we have to use synthetic oil in our M62's. They run so hot that they would fry normal oil. I've been monitoring my engine temps and normal temps are around 115 deg C on the highway and get up to 135 around town.
    I'll be looking with interest in what you are doing as I think I need to do the same with my engine.
    It has a little rattle for half a second when I start it up.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    May 2003
    On The Road
    How does stuff not boil at 135?
    Jan 2011
    Ah yep that could make sense... I’ve only been using full synthetic but that’s no guarantee the last person didn’t! Once I’ve gotten it done I can post a list of part numbers here for you if you like fisherX.
    It’s a pretty straight forward job - but there’s some major things that rave seems to skip over - like how difficult it is to get the injector electronics off - you need a pick tool(s) to remove all the metal cir clips on the connectors before removing the electronics boxes. and the crank bolt.... so tight - a one metre length of pipe over the breaker bar and you could still see it deflect.
    Swapping out the Vanos seals. The ones on the left are the new ones. This was actually pretty easy if you follow the instructions on the Beisan website:
    Beisan Systems - Procedures - M62TU Vanos Procedure
    Jan 2011
    Items needed for timing chain(s) replacement and Vanos rebuild on l322 Bmw 4.4 v8 m62tu:
    upper and lower timing chain and guide kits (I used Febi Bilstein)
    Timing chain kit for crankshaft febi 47500
    Timing chain kit for camshaft febi 47502
    eBay special Vanos rebuild kit
    Extra Land Rover genuine parts so you can put it all back together:
    Part Number Product Item Price Quantity Total
    LR051050.L8 LR051050 AU$54.28 1 AU$54.28
    LYG000120.L8 LYG000120 AU$10.69 2 AU$21.38
    LUD000010.L8 LUD000010 AU$23.02 2 AU$46.04
    PQS000220.L8 PQS000220 AU$39.48 1 AU$39.48
    LYF000030.L8 LYF000030 AU$3.85 16 AU$61.6
    LVF000040.L8 LVF000040 AU$75.47 1 AU$75.47
    LYP000250.L8 LYP000250 AU$23.78 2 AU$47.56
    PYX000050.L8 PYX000050 AU$7.07 2 AU$14.14
    PYX000040.L8 PYX000040 AU$7.01 2 AU$14.02
    LYF000050.L8 LYF000050 AU$3.89 6 AU$23.34
    LR003812.L8 LR003812 AU$72.59 1 AU$72.59
    LR003813.L8 LR003813 AU$75.43 1 AU$75.43
    PET000050.L8 PET000050 AU$11.69 1 AU$11.69
    LVQ000040.L8 LVQ000040 AU$36.43 1 AU$36.43
    LR051049.L8 LR051049 AU$43.62 1 AU$43.62
    LR051048.L8 LR051048 AU$46.64 1 AU$46.64
    tools:
    32 mm socket for Jesus nut
    27mm spanner for camshafts
    water pump pulley holding tool (a must. I had to make one from steel and an angle grinder)
    eBay special timing tool kit for m62 tu
    long piece of steel pipe to extent your breaker bar
    rave manual and Beisan systems guide
    ill let you know how it all goes once done. The new chains are all on now. Just have to put it all back together...
    ps FisherX: my engine was also doing the half second rattle at startup - and then sounding like a diesel if you opened the hood. I would recommend doing it asap. All of the plastic guide parts were so brittle.
    Jan 2011
    Update.
    It runs!!
    Massive job. I went for a low speed drive up my road and back (<20km/h) and it definitely sounds healthier than before. Two issues to sort out tomorrow after work:
    The PAS pump seems to be making some noises when I turn - belt too tight? Or loose? Rave didn’t say what deflection to put in so I just did it by feel.
    There’s a flashing yellow engine occasionally. Could have been in groups of three - but I think I’ll just check everything is plugged in correctly - tomorrow.... fingers crossed M62 TU timing chains and Vanos rebuild
    Jul 2018
    Tahmoor NSW
    How much were the timing chains?
    Jan 2011
    Quote Originally Posted by RSW Vogue 2004 View Post
    The Febi 47500 was $282 off eBay.
    the upper set and tensioners were $75 off eBay (got a bargain though)
    does anyone have the part number for the power steering pipe that connects the steering rack to the lower connection on the oil cooler. It appears the connector on that has gone on mine - I tried reseating it but it exploded putting fluid everywhere while I was bleeding it. When will it end!?!?
    the hose in question is the brown one circled in red.
    Mar 2007
    When are you doing mine?
