Results 1 to 10 of 12
Thread: Blown headgasket
    Two Rocks WA
    Hows this for a blown headgasket on a 89 rangie.
    The heads have been reconned before I bought it and composite gaskets used but the head bolt torque was all over the place.
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Zackly the same as my P38A - blown out the side. The car sounded like a chaff cutter and I had to drive it home (had I known that the NRMA would have flat-bedded it, I wouldnt have driven it).
    Ron
    Pennant Hills, Sydney
    that is a blown head gasket the heads have'nt been warpped buy the incorrect torque being used and buy the sounds of it done buy someone who does not own a torque wrench
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    Apr 2002
    Bellara 4507
    32.43 MB
    i have a head gasket like that on my series landy engine, thru in 3 out of 4 pots and it still ran :P
    smoked the crap out of the yard, but it was running :P
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Avoca Beach
    That is a typical failure, often caused by the outside bolts pulling the head down on that side and therefore up on the other. So next time do not tightedn the outside bolts or better still leave them out.
    You will see no involvement with water passages at all, so no inkling except that the crankcase gets presurised and oil starts blowing out everywhere.
    The head of my 81 had been gone so long when I fixed it, that it had burnt a path into the alloy about 4thou deep.
    regards Philip A
    May 2003
    On The Road
    having not seen the inside of a LR V8 before, I can plead ignorance,,
    but whats the go with the dished valve??
    and why only one?
    Quote Originally Posted by Pedro_The_Swift
    and why only one?
    Actually, Peter, there are 8 of them.
    Ron
    May 2003
    On The Road
    Quote Originally Posted by p38arover
    Ron
    the question still stands,
    why such a deep dish?
    it is hard to tell about the two on the left--
    Two Rocks WA
    and why only one?
    Hello Pedro I have just checked all the other valves in the heads and they are all dished.
    You just cant see from the pics.
    Why they are dished
    I cant answer.
    Brad
    1971 Series 2A
    1989 Vogue auto
    2011 TDV8 Vogue
    SYDNEY -in the shire.....
    they are all like that.....its normal....
    and whilst you have the heads off....get the valves lapped in as well if you are
    not getting the heads serviced.......
