Towe
I’m not fully up to speed on the Ctek unit
But what you say at the end makes logical sense
Victron should keep starter above 13.5V with sun on it (you can manually adjust bulk absorption and float voltages if you want)
(Which is over the trigger voltage for Ctek) so charge then flows from starter to Ctek
Which will drop voltage of cranker and Victron will drop back to bulk or absorption states and pour in current.
Meanwhile the Ctek is taking charge from cranker and it’s own PV input to charge the house bank.
To be honest it is not the most efficient use of power but should work?
With regards to over supplying a Victron
I’ve seen it done! if you feed in 800W of panel the output is limited to 15A
BUT things melt - namely the wiring connection at the input to the Victron!
Not ideal
If it was me (and I know it’s not) I’d lose the Ctek
But a big Victron for the camper
Run heavy cabling via a marine switch from cranker to house
Then have two isolated PV systems
Of house is down and you want to bump it’s charge open switch
Steve
