Results 1 to 10 of 15
Thread: Random air con
    Jun 2013
    Universe A
    Random air con
    Hi guys,
    Just heading interstate and the a/c in the front of our d3 is playing up, I think it might have been for several weeks, but of course now it's more of an issue!
    The front vents put out cold air but not for very long, in fact we were having to turn it off and back on every couple of minutes to get any relief.
    I then told the kids they had to turn on the a/c for their seats and set the temperature all the way down, since they did that the front has been blowing cold for about 20 minutes.
    Any thoughts as to what the problem might be?
    James
    LRD414's Avatar
    Oct 2014
    Search is your friend. Have a read of these threads ....
    D4 A/C Compressor issue
    D3 Air con trouble
    And a detailed explanation in this one, eg post 28
    2013 D4 Air Conditioner Issue
    Regards,
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Melbourne, AU
    Got the same problem - started last summer. Booked in for couple of weeks - going to request they replace the compressor under my extended warranty.
    Also to fix driver's door random not working from outside.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Mar 2016
    Firstly have you ever regassed it? That’s the first port of call.
    After that, the compressor displacement valve can fail, and is cheaper to change than an entire compressor. Simpler is simply a new compressor, but lots of money.
    Beyond that you’re into rare issue territory
    2007 Audi RS4 (B7)
    Melbourne, AU
    Re-gassed last summer when the problem surfaced. It was down a little.
    Didn't really do much to the randomness of the system coming on.
    From reading the threads here it's likely the valve, I'll ask the LR service if they do only that.
    1996 D1 V8 - gone
    Mar 2016
    Quote Originally Posted by jwb View Post
    Unlikely. They’ll want to swap the compressor. Go to an AC place and get them to do it. Process is buy valve (them or you), degas, undo circlip holding valve, regas with nitrogen until valve fires out under pressure, replace valve, vacuum and regas.
    2007 Audi RS4 (B7)
    Jun 2013
    Universe A
    Quote Originally Posted by DiscoJeffster View Post
    Yeah I checked the gas myself last week, all good, I think I did read those threads but couldn't see how it applied to our car, I'll have another look though, thanks.
    James
    Dec 2017
    wandin nth vic
    Quote Originally Posted by shack View Post
    James
    How did you check the gas?
    The accurate way is to weigh the gas . Which means degas and regas yes?
    Dec 2017
    wandin nth vic
    My l322 was cooling to start with then the more it ran the less it cooled. Pressures were all over the place . Degas and regas with correct weight gas and now its great.
    Jun 2013
    Universe A
    Quote Originally Posted by theelms66 View Post
    Just put the gauges on, seemed to be running ok to me
