Results 1 to 2 of 2
Thread: Defender TD5 Clutch Sensor Switch Bleed
    Nov 2017
    Hi All,
    I have just replaced the clutch master cylinder on my son’s 2003 Defender 90 TD5. I am re-fitting the clutch pedal sensor switch after thoroughly cleaning and drying it and re-using the copper washers on the banjo after annealing them. I had forgotten to order replacements but hope the annealing will suffice.
    I have read several dozen threads on the topic of Defender clutch bleeding (and I am sooo looking forward to that ) but none have mentioned any special handling of the clutch pedal sensor switch which to me appears to be a perfect air trap and would seem impossible to bleed. It is after all an upside down dead end pipe at the highest point. Is there any special trick such as squirting some clutch fluid into the sensor switch before fitting or will the normal clutch bleeding process take care of that…....assuming that it is a blue moon and I am holding my mouth the right way? Any tips or tricks are well appreciated.
    Martin
    The secret to happiness is to truly want what you already have
    Oil leak?...Nah, sophisticated anti corrosion system!
    '04 D2a TD5 Manual "Snowy" - Daily
    '04 Def 90 TD5 "Hue" - New toy
    '03 Def 90 TD5 - Son's toy
    '16.5 D4 TDV6 - Gone
    Apr 2007
    MUSWELLBROOK
    Quote Originally Posted by Max Headroom 2.3m View Post
    Hi All,
    Just bleed clutch as normal.
    Never had a problem with the switch only when I was heavy handed on the spanner, new adapter needed.
    Mark
