Results 1 to 10 of 12
Thread: Australian standard approval
    rodney Basford Guest
    Have purchased Vehicle from Queensland - Range Vogue DTV8 L322 2009 has a Warn winch tray. I need blue slip need to know if its Australian standard approved.
    Thank you
    99.87 MB
    Is that even on the blueslippers checklist?
    Slunnie
    That looks like the genuine LR accessory. LR uses Warn winches in their kits.
    Range Rover L322 2002 To 2009 Winch & Mount KNK000060 - Devon 4x4 - KNK000060
    Range Rover L322 2010 On Winch & Mount VPLMP0098 - Devon 4x4 - VPLMP0098
    Land Rover OEM Range Rover L322 2003-2012 Genuine Electric Warn Winch Kit New | eBay
    When I can get to my PC I'll post an image from the fitting instructions (if I can find them).
    Fitting instructions:
    KNK000060.pdf
    Queensland
    That’s Chris’s car - know it well - genuine LR Winch tray fitted so as the other posters have noted its a factory fitted accessory and perfectly legal in Australia.
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    Jun 2008
    I didn't think the OEM winch and winch kit was approved by Land Rover for the TDV8 as it put the front axle over its weight limit (the TDV8 engine being heavier than the petrol) ... Happy to be corrected if wrong here...
    Quite possible.
    Mar 2007
    From Ffrr
    fullfatrr.com - View topic - Front End protection and winch mount (Bull bar)
    TdV8 Winch
    "The cradle was OEM FR for the L322 early one a few tweaks and there you go
    And yes LR said it could not be done (a bit of a red rag to an engineer that statement )"
    No mention of front axle weight !
    Laurie
    If the external winch mount was offered as an accessory in Australia for the L322 TDV8 by JLR Australia then it is legal and fully complies with our rules.
    If it was not offered as an genuine accessory, even if it may be a genuine option offered by LR overseas, then it is not legal until engineered here.
    So where did the mount come from??
    Jun 2008
