Results 1 to 10 of 17
Thread: Welch plugs. Kill me now.
    Feb 2018
    Adelaide
    G’day all. Just curious if anyone know where to source the correct Welch plug for the timing chain end of the 2.25 ? I ordered these but they look way to ‘ long ‘. They shouldn’t sit proud should they ?
    why are you putting it in backwards?
    Feb 2018
    Adelaide
    Ahhh. Well pointed out. I looked at the pictures of the disassembly and it was that way then. So I assumed that was the way it went.
    Redundant disclaimer: I have no idea what I’m doing.
    May 2014
    Tamworth NSW
    Blunt as a bowling ball.
    Couldn't you let him down gently?!
    -Mitch
    'El Burro' 2012 Defender 90.
    Feb 2018
    Adelaide
    Quote Originally Posted by Toxic_Avenger View Post
    Nah. Rather be told I’m a goose and get it right. Welch plugs.  Kill me now.Welch plugs.  Kill me now.Welch plugs.  Kill me now.
    OK..
    Quote Originally Posted by Kimsl70 View Post
    Youre a goose, get it right.
    there are 2 types of the plugs.
    that one goes in the other way.
    the other one goes in that way.
    The key is to look at the doming and the angle (or lack thereof) in the sides.
    The latter one that goes in that way is getting rare, I havent seen one since i did the exact opposite of what you've done and tried to put the one that goes in that way in the other way and promptly knocked it all the way in on the first go. At least it was easy to get out as the lips were facing out.
    Feb 2018
    Adelaide
    Cheers !! I’ll go and have a look. Thanks the reply I appreciate it.
    Sep 2012
    Westlake ,brisbane
    I don't know how you managed to even get it in that way, the out side is slightly tapered.
    JDNSW's Avatar
    The two types are (at least originally) should have slightly different holes. The one shown is designed to go into a smooth sided hole machined as deep as the skirt, and relies on friction (plus whatever goo you put on it).
    The other type is only slightly domed and is inserted as Dave says, with the dome out. It only needs the hole machined for a much shallower depth and must have a machined ledge and a slightly larger groove just above the ledge.
    When the dome is hammered in, this typed of plug expands into the groove to seal. In many applications with only low pressures, and using modern sealants, either type works, although you are better to use the same as the manufacturer used - and note that the hole for a block heater in the Series 2 engine has a screw in plug with a weird thread.
    Feb 2018
    Adelaide
    Quote Originally Posted by 1950landy View Post
    With a hammer.
