Thread: Strange throttle response
    Oct 2017
    Phillip Island
    I don't know if I'm losing my mind or imagining this but I think I may have an odd problem with my Isuzu. A couple of times when driving and just cracking the throttle the Landy seems to slow slightly. It seems intermittent. When I push the throttle further it accelerates properly. The best way to describe the sensation is its like driving a petrol car and you loose all spark. The car is otherwise running like a charm, idles properly, etc. Has anyone else experienced this or have any suggestions ? Have I got a sticky injector ?
    Feb 2014
    Turbo or na?
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Brisbane, Queensland
    I reckon it’s either a fuel or air problem. Strange throttle response
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Hay Point
    Unlikely to be an injector. More like a fuel problem or maybe lack of it. Have you checked that little fine mesh strainer inside the banjo bolt on the lift pump.
    Cheers......Brian
    1985 110 V8 County
    Oct 2017
    Phillip Island
    Quote Originally Posted by Phil B View Post
    Turbo or na?
    NA
    Oct 2017
    Phillip Island
    Quote Originally Posted by Bearman View Post
    There's a good thought about the mesh strainer. I had a couple of hiccups with it at the last service. I cleaned it but didn't have new washers handy so the thing leaked all over the place and let in air. I put new washers in and all was good again, if that's come a bit loose that would make sense. Cheers, I'll check it out.
    Hay Point
    Quote Originally Posted by Zcoota View Post
    Yes, if it sucking air.
    Cheers......Brian
    1985 110 V8 County
