Results 1 to 10 of 13
Thread: TDV8 fault codes - turbo and air suspension
    Feb 2019
    adelaide
    Hi all,
    bit of s strange one, have a couple of issues. 2007 Sport 3.6TDV8
    1. occasionally when driving up the freeway here in Adelaide or up Willunga hill basically under sustained load i get the "engine system fault" on dash car has reduced power. turn car off and on and it is back to normal. this happens more so if we haven't been for a decent drive in a while.
    had the car at local land rover mechanic and he pulled the code P132B-21 - Turbo Charger Boost control A Below Minimum. they seem to think it will require the turbo being replaced as they claim that it is down on power anyway compared to what they should be, but are going to do some more diagnosis first nut aren't that hopeful of it being something else. the car doesn't seem to be down on power to me i thought it went very well, but it is my first TDV8. can given that this is very intermittent and only happens going up a hill is is likely to be a turbo? or could more likely be sensor/actuator etc? i am crossing fingers as they tell me 8-10K for turbo replacement as it is a body off job.
    2. recently after lowering the car so the grandparents could get in and then raising back to normal height i got the yellow light on dash and "normal height only" message on dash. again, turning off car and on would clear this error. it gradually became more and more often until it came on every time when driving. codes pulled were C1A20-64 - Pressure increases too slow when filling reservoir. again land rover mechanic said he has never seen this error and it not be the compressor that is stuffed. they say they have checked sensors and air exhaust valves etc and reccommend changing the compressor and also the filter unit, at $2.5K.
    however after clearing the codes. the air suspension fault has not come back on for 2 days now.
    my questions are do these diagnoses seem normal? or could there be some other explanation. as a 10K + bill to rectify both issues has me
    thanks
    Sep 2012
    Adelaide Hills
    first one sounds like a sticky actuator.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Sep 2011
    Whitsundays and sometimes Sydney
    Quote Originally Posted by Eevo View Post
    same happened on my TDv6, dealer wanted to change the turbo, LRA suspected it was
    the actuator, LRA were correct and after replacement all faults/code cleared,
    Feb 2019
    adelaide
    yes that's what i am hoping they find after some more time diagnosing. after reading on here and other forums i have seen that can be an issue. inter cooler hoses etc are all OK.
    Feb 2019
    adelaide
    Quote Originally Posted by zilch View Post
    ok thanks for the info. do you know how hard/easy of a job it is to replace actuator?
    i'm guessing you haven't had the fault reappear?
    Brisbane, Queensland
    Try spraying the actuator with some penetrating lubricant and try to get it to move with a hook.
    Another possibility is MAP sensors need a clean. You need some contact cleaner and to be careful not to touch the sensors.
    I’m pretty sure you can buy a refurb kit for the compressor.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by rar110 View Post
    this!
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Feb 2019
    adelaide
    thanks will give it a try/suggest to mechanic.
    and will look into the refurb kit
    Sep 2011
    Quote Originally Posted by BPMP_Vogue View Post
    it was replaced by the dealer under extended warranty about 5 years ago and the issue has not reappeared
    thanks
    NSW SW Slopes
    The suspension fault could simply be that the dryer filter is blocked with pulverised desiccant. The dryer chamber can be removed without removing the compressor if you're familiar with the compressor assembly, otherwise remove the compressor first, which can be awkward accessing the top bolts unless you have appropriate socket extensions.
    Avoid using other than standard height until the issue is resolved as the compressor will eventually be unable to raise the vehicle to normal height then the suspension will be dropped to the bump-stops.
