Results 1 to 3 of 3
Thread: Lower Glovebox removal
    I am trying to get to the pasenger side fuse panel behind the lower glovebox. The instructions say:
    Open the glovebox. See
    STORAGE COMPARTMENTS
    . Firmly press the top of the support stay at each end and lower the glovebox into the footwell. A label on the front of the fuse access panel shows the circuits protected and the fuse locations. Remove the panel to gain access to the fuses.
    For the life of me, I can't figure out what I am supposed to "firmly press" on.
    Has anyone done it and could give me some hints, please? I don't want to break anything....
    Numb Thumbs
    NSW SW Slopes
    If its similar to earlier LR glove-boxes then the top of the lever at each side will need to be slightly depressed.
    Is that another lever below the top one? If so then try depressing the top of that one.
    Thank you, Graeme. That got it. One each side plus the slow opener device on the door side has to be released from the plastic knob.
    Numb Thumbs
