Results 1 to 3 of 3
Thread: What parts to replace, if any, before installing pre loved 300tdi
    Jul 2008
    Victoria
    I have come across a 300tdi that has about 250,000klm on it. I want to replace my current engine, which is burning oil, with it and was wondering whether, with that sort of klm's, I could get away with a straight swap as I know its history.
    Given the labour involved in the change over would I be better advised to replace some old bits with new even though I know this one burns virtually no oil and had a new head fitted at about 200,000klm.
    So, what to replace if anything, on the replacement.
    I look forward hearing what you guys think.
    Dec 2012
    Stuart Town
    At an absolute minimum - the rear welch plug. I would also be looking at the rear main seal, the clutch (if manual) and the seal that goes on the gearbox input shaft.
    Tom.
    1996 Disco 1 300TDI manual - Lucille a cantankerous red head! :D
    1997 Disco 1 300TDI Auto - sold
    Jan 2014
    Perth Western Australia
    *apart from service items: oil, oil filter, fuel filter, air filter.
    *water pump.
    *thermostat.
    *all cooling hoses/heater hoses.
    *expansion tank and cap.
    *replace plastic plug in top of thermostat housing and rad with brass ones.
    *get radiator re-cored, repaired etc. (if original brass/copper one, dont get a new alum one)
    *timing belt.
    *serpentine belt.
    *belt tensioner.
    *turbo hoses.
    Daz
