Defender Door hinge bolts
					Hi all
I am replacing the original hinge bolts on my ‘96 300Tdi with torx headed stainless steel ones.
I am having a bit of trouble getting some of them out but soaking in ‘deep creep’ and using a rattle gun helps.  However one of rear side door bottom hinge bolts was particularly tough to remove and stripped the thread on the nut plate.
I taped the nut with an M8 1.25 pitch but it is not correct!  I can’t find anything on what the pitch should be.
Does anyone know what the correct thread pitch is?  I might be better just replacing the nut plate...
Cheers - Simon
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
