Have you adjusted the pre-load on the clutch pedal? Perhaps you don't have any pre-load and the master cylinder is not letting the clutch fully engage.
Hi, I put a new master and slave in 300ks ago and the clutch has just started to slip.
What should I check/do next?
The clutch plate has about 60000 ks on it and I am reasonably kind to the clutch.
check the pedal clearance and the fast fill valve
Many thanks Dave. I was hoping you would spot my post.
I have suffered from a slipping clutch in the past. It was apparent when the vehicle was only hot.
Master cylinder push road required adjusting. I made the mistake of taking all the free play out of it.
Once adjusted, it has been mint ever since.
