Results 1 to 10 of 12
Thread: D3 Mirror Replacement
    Brissy! No flannos here!
    Hi All,
    Needing to replace the entire LH mirror assembly on the chariot, I've reached a decision point.
    One second hand assembly tends to be priced $250-$350, whereas it appears I can purchase a pair of something like this for $300-$400.
    I do tow a van, and being able to fold them in is also attractive as I 4wd.
    Does anyone care to share any experiences with this type of product? Good or Bad?
    Ralph
    Jan 2014
    coonarr qld
    I bought a pair for my bt50, so far they have been great
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Ralph1Malph View Post
    Hi All,
    Ralph
    I decided against as they stick out more than the originals when closed - not so hot for tight spots, but if that is not an issue for you go for it. Having said that they are a bit trucklike.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Hi All,
    Ralph
    I needed to replace the driver's side of mine three years ago and ended up with a second hand unit at the lower end of what you quote.
    Part of the reason for staying genuine was because my research told me that any after market unit (at that time) was not compatible with the HSE memory seat (and mirrors) plugs. Hence it may be that you will need to adjust then manually.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    My old man has a set on his LC200, and aside from making it look like Prince Charles when they are "in" and Dumbo when they are "out", I reckon they are great. I haven't towed his van with them (mine is a lot smaller) but his LC didn't have auto-folding mirrors anyway, so they do everything the originals did and the extra convex at the bottom is pretty swish.
    I have seriously considered a set for the D3, but again my van is a lot smaller and for what we do the clip-ons are fine (and I already own them).
    1.13 MB
    Quote Originally Posted by BradC View Post
    My old man has a set on his LC200, and aside from making it look like Prince Charles when they are "in" and Dumbo when they are "out", .
    These guys sell an alternative MSA 4X4’s NEW Driving Mirrors Built for Work & Play! - MSA 4X4 Accessories which removes to some extent the "Prince Charles" effect. Haven't checked compatibility though.
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
    Jul 2016
    Blackstone
    I recently got a set when I bought my boat. Not pretty but work great. Have not been off-roading with them yet. The small mirrors on the bottom a great for watching the trailer wheels. Haven’t tried, but have heard you can angle them down so you can see the vehicles rear wheels. If so, should help with wheel placement off-road as long as I don’t wipe them off on a tree.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Ok, I've acquired a set of clearview mirrors and as mentioned earlier, the connections and connectors are different.
    This is itself doesn't worry me as I am able change the plugs.
    What I can't locate is the wiring diagram for the mirror circuits for a 2005/6 D3 HSE!
    There are two connectors. I assume one is for the power fold (which I don't have) and the other is probs for the mirror adjust.
    That said, there are no less than 9 wires in the two plugs!
    The clearview have indicators and my old ones didn't so I'll need to sort that as well.
    Cheers in advance,
    Ralph
    Jan 2020
    McGowanastan
    Cheers in advance,
    Ralph
    The extra plug may be for heated mirrors. I seem to recall when I replaced 1 a few years ago there was a plug for mirror heaters.
    Cant help with the rest of the wires.
    Bulletman
    Jan 2010
    Cheers in advance,
    Ralph
    This might help for the indicators from PowerfulUK You are being redirected...
    There are 3 wires on the item :-
    • BLACK - this is the Earth wire ( -VE ) - this connects to the BLACK wire on the side repeater in the door
    • GREEN - this is the wire to illuminate the INDICATOR LED ( orange ) - this connects to the green+white wire on the side repeater in the door.
    • WHITE - this is the wire to illuminate the WELCOME LED ( white ) - this connects to the purple wire on the welcome light at the bottom of the interior card.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
