Results 1 to 10 of 15
Thread: First commercial electric aircraft
    DiscoMick Guest
    Just a start, but interesting.
    World's first fully electric commercial aircraft takes flight in Canada
    World's first fully electric commercial aircraft takes flight in Canada | World news | The Guardian
    Apr 2012
    Whyalla, SA
    Not keen to test that at the moment!
    Lithium power is everything and then nothing. Not a gradual reduction in power.
    Wouldn’t want to be in an aircraft that goes from power to dead!
    Jan 2010
    I thought they were flying/going to fly an electric plane to Rottnest Is. MAybe that doesn't count as commercial as I think it was for sightseeing/tourists?
    Found the link, Australia's first electric passenger plane takes to the skies of Perth, with Rottnest in its sights - ABC News (Australian Broadcasting Corporation)
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Bunbury, WA
    At least it would be power to GLIDE....
    JDNSW's Avatar
    Been there, done that, and it didn't take lithium power - all it took was a dropped valve.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by cjc_td5 View Post
    Small aircraft maybe. Some of the Big buggers don’t fair so well.
    And glide is all good and well if there’s somewhere lower to go!
    Jul 2011
    Yarrawonga, Vic
    I don't suppose regen would work if you feather the prop !
    Bunbury, WA
    That's an interesting concept if you could feather the blades far enough for wind speed to drive the props. I should imagine the glide angle would have to pretty steep though to get much return!
    Bunbury, WA
    Didn't QF38 mostly glide most of the way from its engine failure point back to Singapore?
    JDNSW's Avatar
    No, it had one engine still working.
    But Speedbird 9, after it lost all four engines over Bali in 1982 was estimated to have a gliding range of 91nm and a glide ratio of 15:1.
    Jet aircraft have a rather good glide ratio.
