Results 1 to 9 of 9
Thread: TD5 Crank Position Sensor And Injector Timing Delay?
    Nov 2017
    Hi Everyone,
    I am considering moving the engine ECU (ECM) from under the seat (possibly to the centre cubby box) which will require extending the wiring harness by up to a metre. I would think that most circuits won’t be affected provided that appropriate wire thickness is used and quality connections are made. However I am unsure whether or not the crank position sensor and fuel injector circuits may be affected by introducing a slight delay as a result of the longer wiring. I understand that any delay would be minuscule but injector timing, which is linked to the crank position sensor, is calibrated down to nano seconds.
    I am no electronics whizz so I would appreciate if anyone having experience with this or an electronics background, could advise whether or not a significant delay would be introduced.
    Martin
    The secret to happiness is to truly want what you already have
    Oil leak?...Nah, sophisticated anti corrosion system!
    '04 D2a TD5 Manual "Snowy" - Daily
    '04 Def 90 TD5 "Hue" - New toy
    '03 Def 90 TD5 - Son's toy
    '16.5 D4 TDV6 - Gone
    Apr 2012
    Whyalla, SA
    Won’t cause a problem.
    There is a commercially available extension.
    Melrose SA
    Make sure the cps is shielded like the original wiring
    Nov 2017
    Good to hear that it is do-able. I looked up the commercially available extension which is 2m long (Terrafirma TFEL052) but that sure is an expensive little puppy. I guess it is a plug and play and can always go back to original if need.
    Quote Originally Posted by djam1 View Post
    If I go the cut and splice route then yes I had planned to use shielded microphone cable for the CPS (CKP?) as that has the greatest cross sectional area I could find at 0.30mm2 (22AWG).
    Thanks for your help guys. AULRO wins again.
    Martin
    Melrose SA
    I presume you know about Mulgo’s Xbox
    Pretty sure you don’t need to extend the wiring
    Nov 2017
    I do now and I want one! That is a much better way to go and will resolve some other issues at the same time. I presume all the TD5 electricery will fit in there and yes, it looks as though no wire extension needed .
    Thanks.
    Martin
    Aug 2015
    Mulgo X-Box
    I’ve installed the ECU within the Mulgo X-box. I do however have the Puma 2.2 and there was no need to extend the wiring harness. I did however need to extend the wires for the Bass unit which sits slightly above the xbox.
    Defender MY 2015 110
    Adventures so far!!
    Cape York 2016 Bloomfield,OTT(Gunshot), Frenchmans,Border Ranges, Fraser Isl,Moreton Isl, Tassie(pyengana Jeep track & Montezuma falls).1770
    Nov 2017
    Mulgo XBox
    Quote Originally Posted by Rolly View Post
    Not sure what a Bass unit is but I am pretty sure I don't have one. However, I could be wrong....it has happened. The TD5 engine/ECU and ABS ECU harnesses both pass from the passenger side over the top of the transfer case to the driver's side seat box so I am reasonable confident I should be able redirect them upwards into the Mulgo XBox.
    Probably losing the thread here a bit but what do people use as heat shield insulation under the Mulgo XBox (name, thickness and where to buy)?
    Ta
    Martin
    Aug 2015
    I bought an Aluminium dimpled heat shield from a local auto retailer. Prob 1mm thick and needed tin snips to shape. Whatever you use will be better than not using anything.
    Adventures so far!!
