Results 1 to 8 of 8
Thread: ALDI PRESSURE SPRAY GUN
    Sep 2012
    Westlake ,brisbane
    Just got the latest Aldi Catalogue , they have these pressure spray guns that suck water out of a bucket . I wonder how they would go to spray fish oil in side LR chassis rails?
    Does it work off a pump system or by venturi action? I assume a pump since there is a battery involved but does it pump air (for venturi effect) or the liquid?
    Sep 2012
    Westlake ,brisbane
    When you move posts why can't you say were you moved it to , took me a while to find it . Tool tome is a section I never look in. I would have thought General Chat would be an good place to chat about it.
    Well, there was a redirect for the thread.
    Why post in the wrong area?
    Quote Originally Posted by 1950landy View Post
    Look around the forum a bit more.
    Why? It's about a tool.
    Sep 2012
    Westlake ,brisbane
    It is a case that not all of us a perfect un like some.
    While you may have been disappointed or annoyed at having your post moved, think about the benefits of having it in the Tool Time section.
    People who browse that section to see what is new or to see if anyone has experience with a tool that has attracted their attention, will find it easily amongst the hundreds of threads there rather than in the hundreds of thousands of threads in General Chat.
    Now that you know where it is, you should have no further problems.
    The alternative to having posts in specific forums is to have just one forum called General Chat.
    I don't think it is worth making sarcastic comments about the moderators who do the best they can to make the forum the best it can be.
    Narre Warren South
    Found a manual here https://www.google.com/url'sa=t&rct=...qPRVG1wPbzIQ57
    I read elsewhere it produces about 320 psi but would the internals like fish oil ???
    Probably like battery operated inflators, seems like a good idea but wonder if it's worthwhile.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Geelong, VIC
    I reckon you'd probably be OK for a once-off, but likely the next time you went to use it the seals would be shot.
    I converted an old compressed-air engine wash gun for spraying fish oil inside panels etc. Removed the nozzle, added a hose and plugged the end with a blocked off piece of metal tube with a few radial holes in it.
    Worked well.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
