Results 1 to 10 of 23
Thread: 3.54:1 Range Rover diffs into S2A?
    Mar 2017
    Hunter valley nsw
    Hi All,
    I know there is a thread (or a few!) about this, but I can't find the answer I'm looking for. I understand why the diff ratio change is desirable, and have picked up on the possibility of mixing/matching gearboxes/TCs to get the best combinations of gearbox & TC ratios for road driving and low speed bush work.
    If I wanted to put 3.54:1 diffs in my S2A 88", would I just change the diff centres or do the early Range Rover diffs just "bolt in"? If they bolt in with few mods, it would provide a better braking solution as well I guess.
    Any / all responses appreciated. This is a bit of navel contemplation at present as I try to work out my best options with "Jonesy" my 71 SWB diesel.
    Thanks,
    joe
    Jul 2011
    Yarrawonga, Vic
    if you need to ask then I suggest you don't even contemplate a RRC / D1 Axle swap into a Series .
    You need to cut away / grind off all the brackets from RRC housings , manufacture / weld on appropriate spring perches. You need to allow sufficient room on the front so that the track rod does not rub on the leaf springs, which means higher front spring perches ( lowers the vehicle) . Must maintain RRC pinion upward angle to keep caster angle correct , then you need to cut a big hole in bottom of right engine mount so prop shaft does not hit it. need to convert to power boosted dual circuit brakes . nope not a bolt in conversion.
    10 spline 3.54 RRC diff centres are a bolt in swap into the Series housings. .
    Mar 2017
    Hunter valley nsw
    Thanks for the detailed information. I did need to ask, as I've not done this before. As to contemplating the job, or not, I am capable of many things, but time poor, so the diff centre swap will be the path I go down.
    May 2008
    Bundaberg Qld
    The stage 1 diffs are leaf sprung and 3.54, so that could be a straight swap. The down side is that there are not many around " spare " at a reasonable price. Would give you the large front brakes as well.
    Avoca Beach
    Just be careful to get diffs with the same filler arrangement as the s2.
    Some RRC diffs have a filler on the nose and some no filler plug as it is on the rear.
    Regards PhilipA
    australia
    Quote Originally Posted by pop058 View Post
    hi pop i have stage one diffs here need to take the whole stage one and use the parts jiim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    May 2008
    Bundaberg Qld
    Quote Originally Posted by russellrovers View Post
    PM me a figure please Jim.
    JDNSW's Avatar
    The problem with this solution is that in an 88 the rear diff is a Salisbury one, which would have to be installed as a complete axle assembly. Not only are the spring mounts in a different place from those on the 88, but the diff nose is much longer, resulting in a very short non-standard rear prop shaft and potentially universal angle problems.
    Jul 2011
    Yarrawonga, Vic
    Regards PhilipA
    Ahh yes, I had to add a Fill port on the Metric Disco diff housing I installed in the back of my Lightweight.
    australia
    3 .500 stopped because gearbx problem jim
    Russell Rovers
    Phone 0428732001
