Thread: Can I post?
    Aug 2018
    Tasmania
    Can I post?
    I have a D4 L319 2015 and I would like to post a message for help and advice.
    I have a GAP tool but it is not helping with my problem.
    The problem is as follows:
    Paddle shifts no longer work
    Cruise control no longer work
    Control right side of steering wheel no longer work.
    GAP tool can't find faults.
    Couldn't find any similar posts on the search I made.
    I hope you or someone else can help me.
    Thank you
    Dec 2017
    wandin nth vic
    Sounds like clock spring seeing its all coming from steering column. Someone with that experience will chime in.
    Thread moved.
    The reason you couldn't post is explained here: Can't post? Read this.
    Dec 2009
    SW WA
    I would search for how to remove the SRS Airbag from the steering wheel and see if the connectors are all plugged in as they should be. I don't know if the Clock springs fail completely.
    NSW SW Slopes
    Check the connectors in the vicinity of the steering column, perhaps even before removing the airbag.
