 Fossicker
						Fossicker
						Just asking if anyone has done this and recommendations cheers
 ChatterBox
						Supporter
						ChatterBox
						Supporter Fossicker
						Fossicker
						Yeah I see that there is a threaded one. There’s some sort of sensor in it and I don’t know what it’s for
 Fossicker
						Fossicker
						Have you got the electronic distributor build on the injector pump?
if so thats for and adjustment on the pump as part of the control system.
theres a handfull of ways of getting a boost pressure reading on a tdi depending on what you want to read. if your're after the really easy one, just put a T on the wastegate controller or put one on the line that runs the boost compensator (1/4 inch truck airline pressfit is the one you want) over on the pump side.
 Fossicker
						Fossicker
						Where is the boost compensator thanks
on the top of the injector pump
 Fossicker
						Fossicker
						Cheers Blknight.aus
