Results 1 to 4 of 4
Thread: Series Steering Box and Steering Relay Rebuild Videos
    Mar 2010
    Queensland
    12.97 MB
    Hello Series Fans,
    I have been trawling YouTube for some step-by-step dismantling and reassembly videos for the Series Steering Boxes. I am desensitising myself before I tackle Lazarus my 2A 1963 Ambulance's totally stuck steering box. This is of course a perfect match for the totally stuck steering relay. Since the steering box does not have a big spring that is under load, like the steering relay does - I will build my confidence on the steering box first.
    These videos were accessed 21st January 2020 from:
    YouTube
    YouTube
    I hope these clips are of some assistance to you. If you know of any others please let me know?
    YouTube clips for Steering Relays which show full dismantling and reassembly are still rare. A number show various methods for removing the relay from the chassis. Some show topping the oil up . I am still looking for a more step-by-step example.
    Colin (Gromit) did do a step-by-step guide in photographs for one of his fleet on AULRO. Gromit's Steering Box Overhaul is found at 2a GS Refurb ARN 178-334
    Gromit's Steering Relay Overhaul is located ....Isuzu C240 powered Series 3 However, the photograph hosting site that will remain nameless, has blocked the availability of these photographs. This is a great shame as it lessens a very valuable resource ... hint ... hint
    Reubsrover provided a guide back in 2010 on AULRO Steering Relay Rebuild
    I did find a United Kingdom thread Rebuilding a steering relay - Series Forum - LR4x4 - The Land Rover Forum
    It looks like there is a USA version of the UK tool http://forums.roversnorth.com/showth...269#post106269 The USA version uses adjustable hose clamps instead of zip-ties - UK Version; to hold the spring clamp. Slightly better OH & S in the US of A, apparently!
    Some details of the relay spring compression tool that Mickey W. made in the UK is found at https://forums.lr4x4.com/topic/45650...comment=422486 . From memory Gromit made a similar tool.
    Another version of the Spring Compression Tool made by Andy B. is less complex; however, it does not have the advantage of leverage provided by having handles https://forums.lr4x4.com/topic/45650-600536-steering-relay-compression-tool/'do=findComment&comment=422801
    Two more examples of the Spring Compression Tool are found at https://www.lrukforums.com/threads/s...1/post-1589624
    I found a thread about reducing the lateral movement at the bottom of the Steering Relay by making a thicker collar. For details see ... Steering Relay Collar Improvement - http://www.nickslandrover.co.uk/stee...ar-improvement
    If you have access to the following book there is a fully illustrated description of "how to" from pages 128-133 Accessed 21st January 20202 from,
    Porter, L. (2011). Land Rover Series III Reborn. Dorchester: Veloce Publishing. By the way if you go to
    https://books.google.com.au/books?id...ebuild&f=false
    These very same pages are currently available online "Shhh" The link to inside the book could disappear and be unavailable at any time.
    Kind regards
    Lionel
    Narre Warren South
    Lionel,
    I re-hosted the pictures on Flickr, then they introduced a limit to the number of photos !!!. Pictures are still there but I can't add any more now.
    When I get a moment I could re-write the steering relay rebuild and the making of the compression tool.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by gromit View Post
    Lionel,
    Colin
    G'day Colin,
    Thanks for the reply and for hinting to the compression tool guidelines being rewritten. It would be great.
    Kind regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    I dug out my copy of the Lindsay Porter book Land Rover Series III: Reborn and it mentions on page 132 that... "this is a section of an old leaf spring that Adrian cut and drilled to make a home made version of the Land Rover Relay Compression Spring Tool".
    So there is another alternative tool to choose from.
    Kind regards
    Lionel
