Results 1 to 3 of 3
Thread: Codan 9323 HF Problems - It wont turn off
    Melrose Park NSW
    Went to test my Codan HF and when I switched it on the screen did not fully illuminate and was unable to select any functions. I then went to turn it off and it would not shut down. I checked battery power and all good there. The only way I was able to shut the unit down was to remove the fuse and therefore the power source. I left it for a while and reconnected the power and the same thing occurred.
    Can anyone out there suggest what the fault maybe or anyone know of a where I can get it looked at it would be appreciated. I am in Sydney.
    Chenz
    I do not wish to be a member of any club that would have me as a member
    Former Owner of The Red Terror - 1992 Defender 200Tdi
    Edjitmobile - 2008 130 Defender
    NSW SW Slopes
    One of my sons recently bought one cheaply because it wouldn't change channels. The switches were dirty, only needing to be cleaned.
    Hay Point
    The touch pads are prone to getting what they call a dry contact if not used enough. I had an 8528 that would do that and ended up having to replace it.
    Cheers......Brian
    1985 110 V8 County
