Results 1 to 10 of 11
Thread: Video Camcorders, whats new
    Queensland
    Hi folks, I do a bit of video work ( not that I ever get time to do anything with it ) but I was watching Channel 7 this morning and they had their electronics guru on talking about some of the digital video camcorders on the market.
    Late last year, I needed a new camcorder and I went through all the hassles of trying to find out what was on the market and what were the pros and cons relating to the different makes and formats that were available.
    If anybody is thinking of buying a new video camera/camcorder, the details I found out about the different cameras may be of some assistance to you in making up your decision on what to get.
    I started off by looking at the new Hard Drive types and was very quickly turned off them for a number of reasons.
    The main reason is that, although these cameras are pretty robust, the Hard Drive can be damaged with rough handling and repairs would be exorbitant. The DVD type is even more susceptible to problems caused by rough handling. As I use me cameras in 4x4 situations, rough handling is a major consideration.
    Also both the Hard Drive and DVD require a spin-up time before they are ready to shoot and although only slightly longer than the MiniDV type camcorders, from experience, any additional delay is a problem.
    Both the newer Hard Drive and DVD type along with the now well established MiniDV formats are really intermediate formats but more on that later.
    This left me with only having to decide whether to go all the way to another 3 chip camera ( Panasonic = 3 CCD / Sony = 3 CMOS ) or just stick with the standard single chip camera.
    After talking to a number of camera retailers and seeing how good these new cameras are, I decided to get get a single chip camera and spend up on quality lensed cameras with the highest OPTICAL magnification.
    Through personal experience, I don’t have anything to do with Panasonic products anymore. They have an unbelievable contempt for customers that require repairs, but thats another story.
    After looking around at a number of different cameras and talking to people who use their cameras in a similar manor to my requirements, I ended up buying a Sony MiniDV Handycam.
    This camera is so small that when not in use, it fits easily in my T shirt pocket and this availability has meant that since buying it late last year, I have taken more video than ever before.
    A number of things to look for, depending on how you intend to use your camcorders. I already have a semi pro Panasonic 3 CCD and I take a lot of rail video which means a fair bit of tripod use. The Panasonic’s poor design means that when it’s time to change the MiniDV tape, the camera has to be take off the tripod, the tripod shoe has to be unscrewed and then you can get access to change the tape and then back through it all again, in reverse to get the camera set up again.
    A nifty idea, copied from still cameras, that is now appearing on camcorders is the built-in automatic lens cover. Turn the camcorder’s power on and the cover opens, turn the power off and the cover closes. No more loose lens covers blowing around in the breeze, knocking against the camera and the noise being picked up by the mics.
    Now back to the 3 format, MiniDV Tape, DVD and Hard Drive. All three have advantages and disadvantages, but in my case i have found the established and well supported MiniDV to be the best system, for now.
    In the not too distant future, Solid State technology, similar to that now being used in USB Memory Sticks, will be of such capacity and small enough to use in camcorders and when this happens, all other formats will rapidly fall by the wayside and will not be supported for very long. This was probably, more than anything else, the main reason I went with another MiniDV camcorder. There’s lots of them out there so they will more than likely be supported longer than anything else.
    As to how soon Solid State camcorders will be available is only known by those working on their development, but once they do, the advantages will be many and the more obvious will be almost instant point and shoot operation, the ability of the camcorder to withstand very rough treatment with little effect on the camcorders. Much longer battery operating times and so on.
    Anyway, the above is based on research I did before making my last camcorder purchase and I would be interested to hearing of the experiences of others, both looking into buying a new camcorder or using them now.
    Cheers.
    I bought a new one late last year after my faithful Sony finally decided to give up. (only 6 years but they get a hard life with me )
    I too looked around and spoke to a few of the "experts". The hard part is getting an experienced technical person with no bias but there are some out there.
    I to rejected the hard drive format for similar reasons and because I did not like most of the cameras that use them at the moment. I still like the quality of DV tape so wanted to go with that.
    The 2 specs I really wanted was 1. A 3 chip camera
    2. widescreen format
    Most of the new cameras use widescreen format now but 3 chip narrows the field. Since TV stations and the majority of professionals now use 3 chip technology I really thought this was the way to go. It is not cheap but even now I cant believe the quality of the color.
    I don't have any problems with Panasonic and have only had good dealings with them before so I ended up with a Panasonic GS500. I went with the Panasonic over the sony only because of the lens. Just a personal thing but I think the quality of the Leica lens is better than the Carl Zeiss.
    The only problem I found was when I downloaded my first lot of video. There must be a lot more data to process with the 3ccd camers cause my motherboard would not handle it. I had to buy a new 3.0Ghz motherboard before everything would work ok.
    Maryborough QLD
    Funny that you don't deal with Panasonic, had 2 of there Vidcams and never had any dramas. My first one I dropped onto the concrete and it still worked. The focus was a bit slower than it was before, but I used manual most of the time anyway. But luckily I haven't had to deal with there repairs dept as you have.
    I ended up buying a Panasonic 3CCD job, bloody great camera. Good quality and the price was right. I initially was going to buy the cheaper 3CCD one, but I preferd the next one up in the range (another $500), more user-friendly and a bit bigger (I'm not partial to the real small ones). If I had a bigger Budget, would of bought the Cannon 3CCD model (about $4.5K ) mainly because it's a decent size. I have fat fingers and those bloody buttons on some are far too small, but the Panasonic GS250 that I bought was better than most.
    I agree that the DV tape format is still much better. I looked into the DVD ones, a bit too finiky and personanlly I think they look cheap and nasty. The hard-disk ones, I don''t like the idea if that hard drive within the camera plays up that you have no backup. Didn't look into them, they had just been released when I bought mine.
    Regards,
    Trav
    Queensland
    Hi aquarangie, I bought a semi pro Panasonic ( just before the first of the 3CCDs came on the market ).
    This camcorder was $4,700 and with the extra batteries, ended up a little over $5k.
    I only took a little over 30 hours of video with this camera over a three year period including 5 hours of rail video I took in the first 12 months after I moved to QLD.
    I needed a second camera to do what I was planning to do up here in QLD, so I forked out another $4,500 for a Panasonic, a 3CCD this time. Although both the Canon and the Sony did more, both were an extra $1,000 and I couldn’t see the value for extras that I probably wouldn’t have used. That was a BIG mistake. I have now found that both the Panasonics a susceptible to Microwave interference in their audio.
    This wouldn’t probably be a major problem except I want to video rail operations and most of the main lines now have microwave communications paralleling them. It only occurs if a few places but the two Sony’s are unaffected.
    Enough of that, my main gripe is with Panasonic’s backup service.
    After just over 30 hours use and by then, out of warranty, and only 3 weeks after buying my second Panasonic, my first Panasonic started have software failure indications and would shut down for no apparent reason.
    Because the camcorder was a semi pro camera, Panasonic told there was only one company in QLD that could “ supposedly “ fix it.
    11 months, three returns and $800 later I was left with a camera that some times works, which obviously, is useless.
    I rang Panasonic Australia on numerous occasions to see, if nothing else, could they get this creep company to do something about repairing it or returning it.
    Panasonic’s answer “ If I don’t like the service, they would give me back SOME of my money and I could go elsewhere “. So I just had to wait until they were ready.
    In the interim, I still needed a second camera so I bought a Sony Digital 8. and the first thing I noticed was, and OK the Panasonic 3CCD has good colour separation but the D8 has a much clearer picture and a 20x optical zoom.
    One other difference, both Panasonics suffer from pixilation if handled a bit roughly and I don’t mean dropping them or anything that harsh. Whereas the Sony’s have never caused pixilation and I really give the new Sony a hard time, far more than I ever gave either Panasonic.
    The D8 cost just $1,250 and the new Sony was $1,400 and it has excellent picture quality and one of the main reason I bought it was that all the control settings are done through the Touch screen which is easy to see and quick to use especially as you can set up the controls so that the ones you use the most are on the first page, which makes for very quick changes when needed.
    Anyway, thats my bitch.
    Queensland
    Hi folks, for those of you who are using MiniDV Camcorders, The Good Guys have MiniDV tape at a good price at the moment.
    A pack of three Sony MiniDV tapes are going for $13-50.
    Thats only $4-50 a tape and that the cheapest I have seen so far.
    Cheers.
    LoadedDisco Guest
    Quote Originally Posted by drivesafe
    Cheers.
    Thanks Tim as I will be getting my DVD cam back from the warranty shop tomorrow and will be keen to record a lot of footage to make up for lost time. (Only have about 1/2Hour of 4x4 footage that I have ever recorded)
    Queensland
    Don’t be like me LoadedDisco, I’ve got over 60 hours of rail video and 8 to 10 hours of 4x4 video and with the exception of 2 rail videos I made and sold, a few ago, I haven’t found the time to do anything with it all.
    Sydney, Northern Beaches
    I'm a novice on the hardware side but would be interested to hear what software you use for video editing? I've got access to a lot of 4x4 footage that I would like to compile in a watchable 10 min DVD. I hate sitting through unedited home videos .. I reckon every 2 hours of raw footage is good for about 5 minutes on DVD! Thoughts ?
    Queensland
    Hi Greylandy, my original intention was to make large numbers of hopefully, good quality rail videos and sell them. So to that end I spent over $19,000 on a high end Apple computer and Apple professional video editing software.
    This was without question, the biggest waste of money and time you could imagine.
    Don’t get me wrong, I had no intention of trying to get my money back from the sales, it was supposed to be a hobby and ended up being a nightmare.
    If you want to do some editing, have a chat to Incisor. He’s got some good clews on what’s out there and most of it is free.
    Cheers.
    May 2003
    On The Road
    Hi Tim,, are you talking about micro SD memory?
    A mate just got a new Motorolla phone and the memory card is LESS than 10mm square,
    and there is an optional 1GB card available,
    same size.
    unbelievable.
