Results 1 to 10 of 14
Thread: Can you get locked inside a Disco 3
    Apr 2012
    Coolum
    I have wondered if you were sleeping in the back of the Disco 3 and you got a flat battery whist inside, would you be able to get out or would a window smash be necessary.
    D3 2005 4.4 V8 HSE java Black.Alpine Roof,Alpaca Leather 7seat,LRSat Nav,E diff,Bi Xenon.Hi-Ice et.voice control.Bluetooth Phone.Kaymar rearbar.Roofrails and Racks.18rims.Traxide Dual Battery towpoint Anderson plug. Xenon 4300k Hbeam.10wled450lightbar.
    Jun 2018
    Tamworth
    Quote Originally Posted by coolum View Post
    You'd have to go out a side door.
    May 2011
    Not in my 2005 D3, the door locks worked manually when we lost all power. The tailgate is a different story though, the beer (amongst other important things) was held captive between the cargo barrier and the tailgate.
    Chris
    Mar 2016
    If you double locked it engaging the dead lock the car I can’t see how you’ll do it without breaking a window. That said, you wouldn’t deadlock it if you were in it (alarm etc) so you could simply open the door (I think!).
    That said, it’s a practically impossible scenario I’d have thought. Make sure your fridge has a cutout set Can you get locked inside a Disco 3
    2007 Audi RS4 (B7)
    Apr 2012
    Coolum
    not locked?
    So if the car was not locked when you go to sleep and for one reason or another (radio lights/whatever) in the morning there is no power at all - will the passenger doors open to allow you to get out?
    Or if you climbed over the front will the front doors open? My understanding is the tailgate can't be opened from the inside anyway?
    I have traxide dual Battery setup so it may not ever happen - however if it did and you wake up with the sun in QLD it would be a tense moment till you bang your head on the window enough to either suicide or break glass - whichever comes first (easy to access the jack at the back of course so the headbanging would not be required).
    If it was locked using the key fob - would that mean - no chance in Hades of getting out with an undamaged vehicle?
    Mar 2016
    The door handle is mechanical to the latch so it matters not if there’s power or not. It’s only whether you deadlock it (double press the lock button on the remote). If you did you’re locked in. I think if you lock it with the latch or one button press you can unlock it. First stage lock is manual or button controlled I understand. There are microswitches to make the motor do the “hard work” of moving the latch, but manually it’ll work too.
    2007 Audi RS4 (B7)
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    If the vehicle is locked by using the master lock on the dash then an exit via a side door is possible. Front, open lever to get out; rear, unlock manually and then open lever to get out.
    If locked by the remote then manually operating the latches nor pushing the master lock will unlock the doors.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Mar 2016
    Quote Originally Posted by Narangga View Post
    If locked by the remote then manually operating the latches and the master lock will not work.
    I’m sure that only applies for deadlock, double press, which disables the internal latches. Happy to be corrected (and I’ll go out and confirm now).
    2007 Audi RS4 (B7)
    Mar 2016
    Tested. Using the lock switch internally to lock as you would do sleeping in the car. Lock lever (not electronic switches) allows you to unlock.
    Unlock manually after using button to lock. Sets off alarm (no surprise, so why would you do that inside the car?).
    Unlock after deadlock (double button press) not possible. Latches don’t work.
    All done with power on admittedly but the main lock latch (not lock electronic unlock buttons) and lever are mechanical so power or not should have similar result.
    2007 Audi RS4 (B7)
    1.13 MB
    Quote Originally Posted by DiscoJeffster View Post
    You could also get a trusted friend to disconnect the battery after you have locked yourself in
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
