Results 1 to 6 of 6
Thread: Flogged out auto output spline?
    Kilmore, VIC
    106.38 MB
    What are the symptoms? I suspect mine is about to go. New front diff and half shafts (genuine). Front and rear driveshafts seem fine. Rear diff seems OK. All bushes look and feel good. I get a decent clunk when lifting off or on torque reversal (D to R, etc). Sometimes a nasty bang. Sounds 'central'. Only 140k kms on it...
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    The rubber bush/bearing that supports the rear driveshft?
    Kilmore, VIC
    106.38 MB
    Quote Originally Posted by 101RRS View Post
    It doesn't present like that (more metallic and harsh than a typical centre bearing support failing) and the rear driveshaft feels pretty tight and without noticeable play so I suspect not. I'd be pretty happy if it was that simple and cheap... I'll see if I can get my ridiculously busy indie to assess in the next few days. I've got it booked in for 11Feb but I think I'll have to park it long before then.
    DiscoClax
    Kilmore, VIC
    106.38 MB
    Update
    Had a look with my indie after hours last night on a hoist. One of the front diff mounting bolts had backed out. Tightened them all up and it is smooth and quiet again. All fixes should be this easy/cheap/effective.
    DiscoClax
    May 2003
    On The Road
    Mine has taken to a metallic bang( maybe not quite a bang,,)when selecting R on startup,, doesnt do it with D...
    interesting..
    Brisbane, Queensland
    My output spline after it let go. I didn’t try it in reverse!!!
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
