Results 1 to 10 of 22
Thread: Has anyone used the non genuine steel transmission pan?
    Jan 2020
    Hi Guys,
    Planning a transmission service at home and just looking at all thebits I need to buy. I've found a place near me that sells non genuine pans. They look fine, its just a pan afterall, and will be using the ZF oil.
    Thoughts?
    Seems likea reasonable price. I can't see any issuewith this being aftermarket.
    ZF6HP26 6 speed Steel / Metal Sump/pan Conversion kit FACTORY 2NDS plus 6 x lg | eBay
    Mar 2007
    Canada
    I’m pretty sure they are all genuine pans made by ZF. Metal ones were just used in other applications.
    St Helena,Melbourne
    1.13 MB
    The after market pans are fine .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Hunter Valley
    I've used that pan from that supplier on 3 different cars. All fitted perfectly.
    I would prefer the aftermarket one as it uses standard hex bolts. I have one car that I look after has a genuine one and it still uses torx. A standard socket is easier to access the bolts around the front cross member that torx bits
    It doesn't leak oil, Its sweating power
    Just be aware that some aftermarket pans do not have a drain plug - though the one in the link above does.
    Jan 2020
    Thanks guys! really appreciate the responses. I had a feeling it would be fine, but ya never know!
    Sep 2014
    Baldivis WA
    Quote Originally Posted by Red90 View Post
    Mines a "genuine" ZF pan with a bmw sticker on it, no issues. Still using torx socket head cap screws too. No leaks. went with the thicker gasket.
    Mar 2016
    No idea what I bought. Got it with drain, some super gasket and hex bolts plus filter. Off eBay. Has been fine.
    2007 Audi RS4 (B7)
    South Yundreup,WA.
    I will be oredering one shortly myself.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    LGM's Avatar
    LGM is offline Master Silver Subscriber
    May 2010
    Dongara on the Mid West Coast WA
    Steel Pan
    Has been on my 2011 D4 since 2013. my conversion pan does have a drain plug. The main benefit for me has been that the steel pan allows for a filter change without the mucking around of the LR plastic version required. Bought mine off eBay as well!
    I did notice the add you referred to says 'Factory Seconds'. Personally, those words would put me off that particular one version.
